Author Topic: Opie Oils...  (Read 2492 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Opie Oils...
« Reply #15 on: 26 July 2008, 20:43:55 »
You will be on the floor, on your back, under your car for some time.
You want reasonable weather!
Or timbuk's unit  ;D
Easy enough job, just dirty, I dont mind helping out if I'm free
You've got the job :y
I like red cars
Re: Opie Oils...
« Reply #16 on: 26 July 2008, 22:15:33 »
The problem I have is getting the car level whilst in a position to pour the oil in !!! Too many slopes around here, and on the old miggy I spent nearly 2 hours trying to get it level whilst on axle stands, gave up in the end :( as I didn't want to start the job if I couldn't finish it properly
ATF party somewhere level with a ramp or pit would be really, really, really, good  :y :y :y :y :y :y
Re: Opie Oils...
« Reply #17 on: 26 July 2008, 22:44:05 »
I filled mine on the slant with the driver's side on axle stands then dropped it level to allow any excess to drain out before putting the plug in.
I also have a very useful tool for filling the box, based on a cheap killaspray from Lidl and a short length of 8mm copper pipe.
Re: Opie Oils...
« Reply #18 on: 26 July 2008, 22:56:44 »
Thats the difference .. you have a level to drop it to !! all I have is slopes !!
I was trying to find a level point and the only way was whilst on a jack .... and I don't go under cars just on a jack... lost a friend years back who did that and had the car fall on him .. it was 6 hours they reckon before he was found, he died in hosptial without regaining conciousness... I've always wondered what he went through in those 6 hours ....
Re: Opie Oils...
« Reply #19 on: 26 July 2008, 23:08:34 »
Well, next time you come over to see Patrick give me a shout and you can have the use of my garage floor. :y
How awful. :(
Re: Opie Oils...
« Reply #20 on: 27 July 2008, 05:52:46 »
Would be good to have someone who can replace thrust washers, just in case  ;D
Can't tell you the relief when I dropped the sumps and nowt but manky oil  :D
