Author Topic: One for the lorryists...  (Read 4892 times)
« on: 27 September 2016, 21:14:15 »
Iveco 12E18 rear spring damping blocks...
Are these Donald :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: One for the lorryists...
« Reply #1 on: 27 September 2016, 21:21:57 »
No.
They're still in place for a start; you can see what shape they're supposed to be; there are no chunks missing.
« Reply #2 on: 27 September 2016, 21:25:55 »
Inspite of the relative misalignment of the lower spring :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 27 September 2016, 21:28:24 »
There fine, as nickw says, no splits, still intact, the springs could do with a good covering of waste oil(brush,or spray)
Hoof'land storeman.
  • Chatham, Kent
« Reply #4 on: 27 September 2016, 21:36:31 »
It's a truck leaf spring, not a space-ship!
« Reply #5 on: 27 September 2016, 21:44:27 »
Not my truck, so don't actually care if the back axle falls off or not :D
But it might have explained why the osr inner tyre was bald on the inner 50% :-\
  • Chatham, Kent
« Reply #6 on: 27 September 2016, 21:55:07 »
I bet the tyre fitter was the last person to check the pressure.
« Reply #7 on: 27 September 2016, 21:59:00 »
They don't bother... All the arches are clearly labelled 100psi, yet even newly fitted ones have never been over 85psi when I check them :-X
It's caused a few arguments, but I got a blocking for my vehicle checks... So now I note every single thing. On principal. Seems to have highlighted just how many people aren't checking anything >:(
« Reply #8 on: 27 September 2016, 22:56:26 »
As above... they're actually pretty good :-X ::)
« Reply #9 on: 27 September 2016, 23:16:13 »
Fair dos. Mind you, 32K at 30 km/h is hardly stressful but the tend to be doing either 0 or 30 with nowt in between :D
biggriffin
« Reply #10 on: 28 September 2016, 05:32:25 »
Truck tires wear excessively on the edge due to the camber change, and scrub when manovering,  common on all trucks. When turning left or right the amount of positive and negative, increases on each side, due to kingpin angles.
Your looking for a fault when there isn't one.
Hoof'land storeman.
« Reply #11 on: 28 September 2016, 08:05:18 »
King pin angles on a drive axle ???
biggriffin
« Reply #12 on: 28 September 2016, 12:30:24 »
My mistake.
Hoof'land storeman.
« Reply #13 on: 28 September 2016, 12:43:45 »
I took a Merc 1820 into an alignment place in Cape Town years ago.  The truck had recently been imported from the UK and was chewing front tyres at an alarming rate!
The reason they said was that the roads in South Africa have a different camber profile to the UK. The solution? They bent the front axle with a hydraulic press!  :o
Solved the problem though!  :y.
  • Chatham, Kent
« Reply #14 on: 28 September 2016, 12:46:57 »
Solved the problem though!  :y .
How else would you do it?
