Indicator problems.
Started by Migv6 le Frog Fan, 15 October 2016, 21:32:25
Migv6 le Frog Fan
On the way to work tonight I noticed the indicators had stopped working. My first thought was that I ought to check the fuses in the morning. However as I was turning into work I switched the indicator switch and it came on once and then stopped.
Bad connection somewhere, dodgy switch, something else ?   :-\
Migv6 le Frog Fan
That makes sense, thanks Nick. I may just have a spare in the shed, hopefully. :y
P.S. anyone know what it looks like and where it lives ?
RobG to electrical section please.  ;D
Yellow iirc, on A pillar behind glove box :y
Had same issue on Estate - most likely duff flasher relay.  This is the tall black one in the cabin fuse box under steering wheel.  Replacing this relay on Estate fixed this.  HTH :y
Quote from: Doctor Gollum on 16 October 2016, 01:15:40
Thinking back through the mists, this might have been the cure to one side failing...
That one is white and controls the alarm indicators ;)
Migv6 le Frog Fan
Black relay change and problem fixed. Thanks for the info.  :y
Quote from: Migv6 on 16 October 2016, 14:01:43
Find it in the box of goodies??
Migv6 le Frog Fan
Yep.  :) Ive also had my moneys worth out of the code reader over the last few months.  :y
PM incoming shortly Rob.
Quote from: Migv6 on 16 October 2016, 14:05:21
Migv6 le Frog Fan
I typed out a long PM but lost it in the ethe just before it was finished. Don't know if it arrived ?  ;D
Have now sent another one.
