What are the differences between the Omega B1 and B2? Are they only cosmetic?
Started by anV6, 16 October 2016, 12:08:13
anV6
This is all very interesting. It's really surprising that the so called sports suspension has very little difference from the standard. I was expecting different geometry or at least something more than just stiffer springs.
I wonder what Lotus did to the Lotus Carlton suspension that every reviewer said it was handling like the Lotus sports cars and was a dream to drive.
Diamond Black Geezer
There's a couple of ex- LC / LO owners on here who will be able to explain that in fair detail between normal Carlton and the Lotus variant.
As for the suspension changes between Omegas, I think there was very much a feeling of 'if it aint broke, don't fix it'. The MV6 was never really a massive full-on track-munching sports machine like the old Carlton GSi 3000 was, cosmetically the MV6 never looked very far from the humblest GLS model. The suspension was a little lower a little stiffer, and that was fine, given it had a well-proven rear-drive chassis and decent dynamics. They weren't trying to make it an M5 eater (not forgetting they tried and succeeded in that with the Lotus, but for no real benefits, the whole Lotus Carlton Omega project basically cost GM money, especially after sales slumped due to the early 90s recession, which also affected XJ220 etc)
it was a bit nicer than a 'normal' omega to drive - and that's fine  :) I have to say, I'm on MV6 springs on mine, and going from a FL with standard springs it's a fair bit tighter, and still rides 90% as well.... however I'd go back to the standard setup tomorrow without really feeling like I'd 'lost out'.
If you're after a lower and harder ride, then kits are out there.  :)
Mr Gav
Quote from: anV6 on 20 October 2016, 12:05:40
The MV6 also had firmer damping and IMHO were better than the Bilstein B4`s and with 20mm lower stance wasn`t a bad handling car, what lets the Omega down is the bushing on the front wishbones and the powerflex bushes sort this out  :y
The Lotus Carlton had self leveling suspension but that`s as much as I know about it, I suspect the geometry was different because the front wishbones are different as is the front wheel offset.
anV6
Quote from: Diamond Black Geezer on 20 October 2016, 13:21:06
By that I get the impression that if i don't get a MV6 I shouldn't bother in trying to upgrade the suspension to match the MV6's sports suspension?
Which ones? :)
anV6
Quote from: Mr Gav on 20 October 2016, 14:20:45
Are the Bilstein B4s you mention the stock dampers in the non MV6 models?
And what are the Powerflex bushes? I get the feeling I will have to start a list of upgrade musts for the Omega.  :)
So you think the Lotus Carlton self leveling may have made all the difference? But the standard Omegas also have that right, but in the MV6 sports suspension it is eliminated? Or this wasn't what Doctor Gollum meant when he said no self leveling facility for the MV6 suspension?
Quote from: anV6 on 20 October 2016, 14:52:07
You certainly should if it's an Elite. Possibly less so for other models without self-levelling. Not familiar enough to know.
Having said that, MV6 suspension bits are rare now, so probably not worth seeking them specifically. Pattern suspension parts such as the B4s are probably a better bet, although if you happen to come across some decent MV6 springs, snap them up. :y
Quote from: Kevin Wood on 20 October 2016, 14:58:05
I did!  ;D Actually surprised I havent seen any come up since, glad I got them when I did.  :)
As Kevin say OP, worth keeping your eye out, however there are 'other' options (aftermarket springs which are stiffer and lower - depends what you want, really, how far you want to go etc)
Sachs were OE shock provider... Bilsteins ok, but the have fitting issues...
Eibach do a decent range of springs :y
Irmscher stuff occasionally pops up, especially on ebay.de...
Mr Gav
Quote from: anV6 on 20 October 2016, 14:57:16
These replace the totally shite front bush in the front wishbone, it`s this bush that gives the omega the vague steering feel and the powerflex bushes are polyurathane and give a more precise feel to the front end.
anV6
So is self-levelling bad? By what I have been reading here and the fact it has been deleted from the MV6 sports suspension I get the impression it is undesirable. But it was said the Lotus Carlton had it, which would make me think Lotus thought it was a good thing. I would also have thought so.
Quote from: Kevin Wood on 20 October 2016, 14:58:05Having said that, MV6 suspension bits are rare now, so probably not worth seeking them specifically. Pattern suspension parts such as the B4s are probably a better bet, although if you happen to come across some decent MV6 springs, snap them up. :y
Sure. But I get the impression there is nothing special about the MV6 suspension, or? Can't you replicate it with after market parts? It's just different dampers and springs right?
anV6
Quote from: Diamond Black Geezer on 20 October 2016, 15:26:50
What are the after market options? I don't want something scrapping on the floor. Nothing too low. Something as low as the MV6 or even Irmscher would be fine. Not too stiff either. The M5 is not that stiff right? It is still comfortable but handles well enough.
anV6
Quote from: Mr Gav on 20 October 2016, 18:49:02
Great to know. Thanks!
anV6
I've seen that one before on the web/oof. Right, that's standard FL MV6 fayre, with the additon of...
little chrome strip things on ashtray
-Ebay/aftermarket stainless steel dial rings
-Ebay/aftermarket dials (as above) may be Richbrook but there are companies who will make you custom dials. These being from Germany rings a bell.
-Phone and air freshener are obviously aftermarket.
-The little 'box' on the top of the dash also is non-standard.
-The screen / display in the speedo binnacle is unusual, but are about. It's a colour screen, and rather sought after. I've seen people on the continent hack them to provide a reversing camera feed, display a ncie opel badge, even a TV/DVD feed, all sorts.
The gear lever isn't standard, either. Not sure what's going on here, but most likely replacement gearbox. I assume, therefore there's a V8 under the bonnet, and that's a tranny out of a Corvette or something else 'beefy'
-Little button next to the gearlever. The 'snowflake' button is on all Auto Omegas, but the square thing below is what's added on & could be anything.
Annnd breathe! I think that's it!  :y
