What are the differences between the Omega B1 and B2? Are they only cosmetic?
Started by anV6, 16 October 2016, 12:08:13
anV6
I'm interested in knowing what are the differences between the Omega B1 and B2. Are the differences only cosmetic? I know the B2 has a new interior, new tail lights and rear bumper and new bonnet and front bumper. But is that it?
And are there also mechanical and electrical differences? I know the engines were replaced in 2000. But what about the rest like suspension etc?
And by the way, does the Omega B share anything with the older Carlton-Omega A? Like chassis, suspension etc?
Thanks.
anV6
Thanks. I had looked through that and as well as the FAQ. But I didn't really see the answer for my specific questions. Unless I overlooked something.
Edit: Yes, just looked again and the answer to my questions are really not there.
Mechanically identical. Better paint techniques make facelift less print to bodywork corrosion, particularly on the doors.
New engines came in after the facelift, so you can get facelift cars with older engines.
Climate is a lot more advanced technically, but in reality doesn't deliver noticeable refinements. Seat heaters have better heat adjustment on facelift cars, rather than the on/off of pre L ones.
Everything else is cosmetic.
anV6
Thanks!
At the front, what exactly is different? Looking at it it seem the B2 has a different grill, a different bonnet and a different bumper. But headlights and wings are the same as B1. Or am I wrong?
And would you know if the Omega B shares anything mechanically with the Carlton (Omega A)?
Bonnet, headlight and bumper. That's all that's needed to make front end look like an Astra-G
Although based heavily on the Senator/Omega-A chassis, sharing the same V-Platform chassis, I can't think of anything that's identical.
Quote from: TheBoy on 17 October 2016, 10:29:34
Bonnet, headlight and bumper. That's all that's needed to make front end look like an Astra-G .....
Oy! That's my line!  ;D
anV6
So the headlights are also different. I thought they were the same. But so there are no structural differences underneath? One can just buy the headlights, bumper and bonnet and bolt them right on without any custom work needed and convert the front to a B2 or vice versa?
I heard the Omega B was heavily based on the Omega-A. So I thought if the chassis is the same, maybe the suspension would be too, or at least very similar. Are the dampers, springs, bushings etc all different? Brakes?
All different  :'(
But yes, front end can be retrofitted :y
Wings are the same btw ;)
anV6
All different as in the dampers, bushings and springs from the Omega-A won't fit? And why the tears?  :)
Good to know it's easy to change the front end though. If it's as simple as bolting off and bolting on then it's easy.
anV6
By the way, what are the differences between the standard suspension and the sports suspension found in the Omega MV6 and Omega Sport?
Quote from: anV6 on 17 October 2016, 14:05:32
About 20mm lower with slightly stiffer springs, no self leveling facility. Otherwise identical  :y
anV6
Quote from: Doctor Gollum on 17 October 2016, 15:00:27
And only that makes the whole difference? According to some the sports suspension handles a whole lot better.
And I wonder how less comfortable it is since it's lower and stiffer.
It doesn't sound like much, but it tightens the handling up nicely. Ride isn't really affected as it has the same size wheels and tyres as the Elite :y
Mr Gav
Quote from: anV6 on 17 October 2016, 12:37:56
The front hub assembly and rear wishbones are identical and that`s about it, the springs and dampers will physically fit but the rates will probably be wrong, at the front at least anyway.
