Author Topic: sport estate  (Read 1189 times)
buckers
sport estate
« on: 27 July 2008, 18:06:17 »
i've just bought my third omega a 2.2 manual sport estate. after two elite models i miss the cruise control but i've heard rumours that itis easily fitted. is this true?
Jay w
  • Plymouth/Poole
  • omega gone
Re: sport estate
« Reply #1 on: 27 July 2008, 18:11:06 »
if it is drive by wire then yes it can be fitted easily.
will need a new stalk and a session with a piece of kit called a tech 2 but that should be it
Re: sport estate
« Reply #2 on: 28 July 2008, 18:56:53 »
Yes, You will need to add the stalk, check the Brake switch, and probably add a clutch switch.
Then just a quick chat to tech2 and your done  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: sport estate
« Reply #3 on: 28 July 2008, 18:58:31 »
Manual Gearbox switches?
Re: sport estate
« Reply #4 on: 28 July 2008, 18:59:47 »
Not to my knowledge
Sure there is a guide in the maint section.
zirk
  • Epping Forest
Re: sport estate
« Reply #5 on: 28 July 2008, 19:12:02 »
Not to my knowledge
There fitted on my Tractor, if you pull it out of any gear with out using the clutch (dont aways use the clutch on mine), it kills the Cruise !, must be netrual swicth sensor?
Re: sport estate
« Reply #6 on: 28 July 2008, 20:07:52 »
Not to my knowledge
Tractors very different. DBW as well I think  :-?
