Central locking won't re-set
Started by powerslinky, 30 October 2016, 09:19:36
powerslinky
Ok . . . following on from strange goings on with the rear window operation  . .
Had this car a few weeks now & locking from the fob has always worked fine :y
However deadlocking did not or neither did the central locking re-set  ( doors closed key in at position II & push lock or open )  See below as deadlocking now fixed
Any ideas where to start on this .
Was hoping that as the puddle light pin switch problem has fixed the rear window issue
( see other thread "Strange rear window fault" ) & the dead locking that it may have fixed the re-set of CL as well but no joy  . . .still won't re-set  :'( :'(    :y
Any advice where to look on this one please?
Edit:  unless of course the re -set will only work if it needs doing ,as in not locking from the fob . . ::) ::)      if thats the case plenty of these :-[ :-[ :-[ :-[ :-[ :-[ :-[ :-[ :-[ LOL!
Chazza12
I dont know if this would help but when i was looking round for my problem, I found a pic of a central locking unit that had water in the socket. ( all green on connectors ) and is problem was around the same fault as yours.  shaw it said it was water getting in somewhere on the side. hope this helps.
biggriffin
 check both front solinods, and lubricate the latches were all the rods join.
Hoof'land storeman.
