My Energy Supplier
Started by TD, 17 November 2016, 17:53:16
TD
For the last two quarterly bills they have been telling me I can save money if I switch tariffs
The tariff I'm on and the tariff they want me to change to are both fixed price tariffs
The tariff I'm on ends March 2017. The tariff they want me to change to ends Dec 2017.
They tell me I can save £32 on my leccy and £36 on my gaz if I change.....
Looking at the prices between the tariffs I fail to see how....perhaps someone can tell me  :-\
Tariff I'm on prices
Leccy is 8.882p/KW . SC is 16.96p/day
Gaz is 2.73p/KW . SC is 16.96p/day
Tariff they want me to change to
Leccy is 9.96p/KW . SC is 20.55p/day
Gaz is 3.08p/KW . SC is 20.55p/day
So seeing how the price per unit and the SC is higher on both leccy on gaz I fail to see how I'm suppose to save the combined total of £68 in a year!  :-\
Unless any has any ideas how they worked that out I'm mystified!  ::)
They have assumed that when your current tariff finished you will go onto their "standard variable" tariff which is probably a complete ripoff.
The fact is, of course, that you'll go elsewhere and probably save even more.
Quote from: Kevin Wood on 17 November 2016, 18:00:17
That's right, Kevin. From March-December 2017, they will have put you on the full price tariff, Dave. Uswitch use this method too. They assume that you are too thick to change suppliers when your deal runs out.
Quote from: STEMO on 17 November 2016, 18:12:10...
or just can't be arsed .... or better the devil you know. I switched to some 'cheaper' deal years ago & they made such an arse of it that it made me very reluctant to ever change providers again.
TD
Ah...that'll explain it Kevin....thankyou  :y
But I have until March next year to switch tariffs.....so I guess I'm better off staying on the tariff I'm on and switching then  :-\
Plus its a bit more complicated...This took 6 months to set up...My Mum is also with my energy supplier....I can see all her energy usage and change any details on her account, from my online account....so reluctant to change energy supplier.....
Shackeng
And don't forget if you decide to swap, to do it through a cashback site. First Utility for example are offering £110 on Topcashback at the moment. :y
I switched from British Gas to Eon a couple of months ago and when I got my final Electricity bill from BG it was about £60 in credit!  :y  I was surprised at this, but then saw they'd used an estimated reading which was way short of reality.  ::)
So I phoned Eon who said that they hadn't set up my electricity account yet, but not to worry it would be done soon.  ::)  I phoned BG to tell them that their estimate was inaccurate and that Eon would be sending the meter reading soon, and not to send a cheque as I probably owed them money.   :)
Today I got a cheque from BG for £59.78!  ::)  Retards!  ;D
So should I :-
a) Return the cheque with a polite letter explaning the situation.
b) Keep the cheque and see what happens.
c) Bank the cheque and let British Gas fight me for their money back.
TD
Quote from: Sir Tigger QC on 17 November 2016, 20:51:02
So should I :-
C, as you'll need it to help pay for the plumber/new boiler/new central heating   ::)
I wonder if you could argue it was BG gas that broke your heating and they should pay to fix it  ::)
Quote from: TD on 18 November 2016, 07:52:12
At British Gas prices?  :o What do you think they are, made of money?
I think TD has a point as British Gas were clearly selling me sub standard gas!  >:(        ;)  ;D
Quote from: Sir Tigger QC on 18 November 2016, 11:11:21
.. and shoving it down the wrong pipe so it ended up in your radiators. Shocking behaviour. ::)
TD
Quote from: Kevin Wood on 18 November 2016, 12:05:24
That would explain why Sir Tig has burbing noises in his central heating...  ::) ;D
Thinking about it, my boiler started hicupping after I switched, so maybe it dosn't like Eon's gas?  :-\                                                      ;D
TD
Quote from: Sir Tigger QC on 18 November 2016, 17:58:56
Sue them as well then  :y ;D
Tony H
Spend a bit of time on comparison websites, make a list of the best half a dozen deals then contact the suppliers directly. Inform them that they have made your prefered short list and you will be contacting all just once  for there best quote, inform each supplier that they will only get "one bite at the cherry" to give you the best deal. From experience some of the companies expect you to haggle but it saves a lot of time to tell them to just "cut to the chase" with the price. Good luck  :y
