Meriva 1.6 EPS light on and power steering failed
Started by terry paget, 20 November 2016, 12:41:11
terry paget
As heading, checking out my sister's 1.6 manual petrol Meriva, which has not moved for 3 weeks. Recharged battery, started engine, driving it back to my place to service it, EPS light came on and steering went heavy. Please advise how to rectify.
Is the battery any good?
How well is the alternator charging?
Has some muppet fitted Fiat Pinto EPS by mistake ;D?
terry paget
Quote from: Nick W on 20 November 2016, 12:53:18
Thanks for the quick reply, Nick.
Battery dodgy I think. It is a Varta, unknown age, and sister has never changed it in her ownership, last 6 years.
Alternator charging well - 14.6v at idle, falling to 14.3 with all lights and flashers on.
On engine restart EPS light went out and power steering returned.
I don't know how electric power steering works. I suspect it is still hydraulic, but the pump is electric motor driven on demand, rather than constant belt drive, to improve economy. All very well, but less reliable than belt, and may draw large current when doing duty. I am minded to replace her battery with a spare on my bench off a scrapped Omega.
I have no reason to suspect Fiat Pinto kit fitted. I imagine you have met this before!
biggriffin
Quote from: terry paget on 20 November 2016, 15:04:59
Don't!!!
It's your sisters fit a new one, for piece of mind and longevity about £35.00.
I've just had this argument with my father regarding my mums car, "fit that spare battery that's on the bench"
"er no, I'll put a new one on £39.00, from Halfords, on trade"
Hoof'land storeman.
terry paget
Quote from: biggriffin on 20 November 2016, 16:36:51
Don't!!!
What' to go wrong, biggriffin? The worst it can do is fail to start one cold morning. If it does that I can fit her another one.
biggriffin
#5
Quote from: terry paget on 20 November 2016, 20:42:13
Don't!!!
. Worst case.!
The steering might fail, but you saved 59p.
It goes flat away from her home, or it goes flat at 04.00, you going to sort it,. We all want to save money, there are something's that aren't worth it a battery is on the list, fit and forget.
Hoof'land storeman.
terry paget
Quote from: biggriffin on 21 November 2016, 03:21:35
Don't!!!
. Worst case.!
My father always replaced his cars every 2 years, and advised me to do the same. I run and maintain 6 Omegas, a Meriva and a Streetwise for my near family and have done so for many years. The youngest car is 9 years old, the oldest 16. They have proved to be safe and reliable. When I scrap a car I harvest any parts I think re-useble.
I regard batteries as devices to store energy for starting, and ballasting alternator voltage, not as vital steering components. When the EPS failed on my Meriva journey home the car was still quite driveable, just lacked steering power assistance. Until Nick mentioned it, it did not occur to me that battery condition could affect power steering. seems a retrogade step to me. I still do not know how electrical power steering works - is it hydraulic with an electric pump?
Let's not have a row about it, BG. I respect your point of view, but am a hopeless miser.
Quote from: terry paget on 21 November 2016, 17:58:03....
some are ... my astra G was like that (and when the V belt snaps you have no assistance at all and it's still really heavy even when you're moving) and others have the motor directly on the column  :y
citroenguy
There are two types of electric power steering, electro-hydraulic and full electric (a motor on the rack).
Electro-hydraulic is a traditional pas system with an electric pump, usually located in front of one of the front wheels inside the wheelarch.
Full electric is a electric motor mounted directly to the steeringrack. On the Meriva A i think it is located inside the car, Just like on the Corsa C
Most post Omega cars are touchy about the battery voltage..
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
Migv6 le Frog Fan
I believe it may actually be the same system as the Fiat Punto. My son has a Punto and his PAS motor cuts out sometimes when held on full lock for more than a couple of seconds. Its also common for the motor to cut out completely on these.
Its normally temporarily curable by switching off the engine and restarting.
I read a report which said it could be cured by replacing the relays in the PAS motor with different ones, so I had this done but it didn't completely fix the issue.
I believe the only proper fix is to send the whole steering column off to BBA reman to have it rebuilt.
Cant remember how much it cost, but it may be available on their website.
citroenguy
On a semi OT note. Some Audi A6s with electro-hydraulic pas wont start if parked at full lock  ;D :D, due to the voltage drain by the pump..
124k on the C5
Quote from: citroenguy on 21 November 2016, 18:34:57... and full electric (a motor on the rack). ....
& as said, some are on the column ... that's what the lump in the column is  ;)
terry paget
Thank you gentlemen. Now I wonder how the motor on the column or the rack works. It must take a hefty current to respond as quickly as is necessary.
citroenguy
124k on the C5
Quote from: terry paget on 21 November 2016, 19:47:23
The column mounted ones are just a worm gear, driven by a hefty electric motor. Mechanically it's simpler than a hydraulic system, and as it doesn't require a pump spinning all the time means the manufacturer can claim a 0.0582907MPG(approx) saving.
