Power steering pump question.
Started by ted_one, 21 November 2016, 20:30:26
ted_one
Are the power steering pumps the same across the range of models? say for instance are the 2.0/2.2 pumps the same as the 3.0/3.2 pumps.  :-\ TIA
Migv6 le Frog Fan
Nope. Don't know about the 4 pot versions, but later cars 2.6 / 3.2, were different to the earlier 2.5 / 3.0.
ted_one
Likely then, that those variations would apply to the 4 pots as well. :y
Diamond Black Geezer
And there's the servotronic (or thereby lack of on 4 pots) as well.
I think that you can fit any V6 one to another V6, but the piping needs changing, too. (which offsets somewhat the £2 or whatever you've saved in getting the 'wrong' pump if you then have to source the associated pipes, too)  :)
Bojan
All X-gen petrols (2.0, 2.5 and 3.0) have the same PAS pump.
Diesel have diferent.
3.2 and 2.6 are another diferent model.
It doesn't matter if it is servotronic or not - that is in stearing head.
biggriffin
2.5/3.0 won't fit 2.6/3.2 and vice,versa.
Don't know about little ones.
Hoof'land storeman.
Ooh, I always 'knew' that you needed different pipes, but the pumps were interchangeable between early and late V6s.. though I've never actually done it personally. Fair enough
Migv6 le Frog Fan
Quote from: Diamond Black Geezer on 02 December 2016, 14:37:00
Correct.  :y
Ta Mr MigV6  :y   The problem we, and of course a squillion other blokes before us have is discovering the difference between 'not the same part' and 'it won't fit'
I saved a few quid on my HTs by fitting Vectra ones, even though 'they're too short and won't fit'... but they do  :)
