EML & Codes
Started by Colin G, 24 November 2016, 17:13:43
Colin G
Had my EML come on - car seems to drive fine but I've logged the following codes -
P0170: Fuel Trim (Bank 1)
P1130: [Chrysler] HO2S Circuit Low Variance Bank 1 Sensor 1
[Ford] Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
[Toyota] Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 1)
[Nissan] Swirl Control Valve Control Solenoid Valve
[Lexus] Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
[Mazda] HO2S Bank 1 Sensor 1 Not Switching (Fuel Control Limit Reached)
[Dodge] HO2S Circuit Low Variance Bank 1 Sensor 1
[Jeep] HO2S Circuit Low Variance Bank 1 Sensor 1
[Seat/Audi/Volkswagen] Long Term Fuel Trim mult.,Bank2 System too Lean
C343B: Unknown code - More information may be available on the web
P0111: Intake Air Temperature Circuit Range/Performance Problem
P3911: Unknown code - More information may be available on the web
Does the above suggest the MAF?
Cheers
Col
Not necessarily.  What was the MAF's live data reading at idle, and at 2000rpm?
Colin G
At idle it was around 5.5 and when doing 30mph at around 29 - recorded using Torque Pro
