Rear Light Cluster Lens broken
Started by sirmally2, 27 November 2016, 23:02:40
sirmally2
Hi all,
I've ordered a replacement part from Evilbay as the old man reversed in and a branch has gone thru the lens of the rear lights
Its the set on the Boot lid and not the corner.
How much of a ache in the gonads is it to change? or is it just a few screws?
cheers
mal
BazaJT
Looked at my f/l 3L[assume they're all the same]so open boot there should be a plastic cover where light cluster is.Squeeze the outer collar in the centre of this and at the same time pull this removes cover.Then it's a matter of undoing 3 small nuts and disconnecting electrics,then push light unit out.Replacing is as they say reversal of removal.Personally before refitting I'd clean the edges of the opening and apply a thin beading of silicone to prevent any water ingress/leaks.
Quote from: BazaJT on 28 November 2016, 11:56:37... and apply a thin beading of silicone to  .....
You might want to get it off again ...  ::)
omegod
easy, 10 minute job, including tea and bacon roll... :y
sirmally2
Thank you Chaps... Another job to get ticked off the list once the bit arrives.
Thought it might be simple however always best to ask the people in the know :-)
