Can't. Post
Started by Figureman52, 01 December 2016, 13:40:20
Figureman52
I need some help on this one.
Firstly, I can read all posts on the forum from any device through my cable internet connection, the same connection via WiFi or on 3G.
I can't post anything at all to the forum via my PC.
I can start a new thread on SWMBO's android smartphone via my cable connection using WiFi but I can't update the thread or reply to any other thread.
All posting works fine on the smartphone when using 3G.
My last post was on 06 October from my PC.
The PC is running Zorin9 which is a version of Ubuntu 14.04 and has been for the last two years. I have tried posting using Firefox 50.0 and
Chromium Version 53.0.2785.143
Any replies from me may be delayed until SWMBO stops using her phone!
Thanks.
henryd
I'm the same.can post at home over wifi and at work from phone but computer at work runs 3g dangle on t mobile and can't post from that on
other rides
zirk
I had, and still have the same posting issues, see here, -
http://www.omegaowners.com/forum/index.php?topic=137724.0;all
When ever I try and post or reply, update etc, just get taken to a 'Start New Topic' page then goes around in circles.
Found if I use 'Quick Reply' or went on the 'Wap2 Site' it would work, but now that is 50/50, ended up posting reply as normal, which failed, go back Copy and Paste my text to Wap2 site then back on Main Site was the only way it would work for me, and now thats all trial and error.
Only way I can post is to use my Andriod Phone or VPN my IP address outside of the UK.  :D
I believe someone fixed something that wasn't broken.  :-X ;D :( :-*
FM - you using an pre Evil Everywhere Evil Everywhere connection, such as an ancient T-Mobile datasim?
Figureman52
#4
If I understand the technical terms correctly, then no.
My internet connection is Virgin Media 50mbps and my sim is also Virgin Media: 250minutes, unlimited texts, 1Gb Data, 30 day rolling contract.
The same setup I have had for several years
Just discovered I can still post using WAP2
henryd
Quote from: TheBoy on 01 December 2016, 18:50:14
I'm using  the same dongle that I had when I joined here,always worked until recently,works on everything else I'm on but not here.
other rides
TB's cull has started  :)
zirk
Quote from: STEMO on 01 December 2016, 22:46:40
Well He's obviously got the locations wrong........     what was your Post Code again.  :P
I suspect EE have some old, misconfigured transparent proxies.
If you have Parental Controls type filtering, does it help to disable it?
Figureman52
No parental controls. Don't understand the connection to EE as I am on VM.
VM also use transparent proxies, although reply was to Zirk.
What exactly are you seeing? Is it simply the Post button doesn't respond (javascript being bastardised somewhere), or it takes you back to blank post window (lost session)?
Figureman52
#11
Click on post, after around 30sec I get the message:
"The connection to the server was reset while the page was loading."
Clicking on try again results in a blank post window.
zirk
Quote from: Figureman52 on 02 December 2016, 20:02:18
Virgin Megia or Virgin Mobile, Virgin Mobile use the older T Mobile Network, although now EE, T mobile (together with Orange) get routed through differently to existing EE Customers on their Network.
Quote from: Figureman52 on 03 December 2016, 12:45:21
Sounds like you're losing the session - I suspect you're being bounced around your ISP's proxies?
Figureman52
Anything I can do about this?
