Fault codes
Started by stu24v, 01 December 2016, 19:54:56
stu24v
Car got miss fire fault codes 030 came up any ideas on parts to replace plus cost cheers all
0300 is the code for random miss-fire. On it's own it doesn't tell us anything usefull.
What are the symptoms?
When were the spark plugs last replaced? Any oil or water in the plug wells?
BazaJT
Quote from: BazaJT on 01 December 2016, 20:14:04
What engine?
Doesn't matter particularly  ;)
Either water or oil in the plug wells ;)
Remove coil pack(s) and report back  :y
stu24v
Cleaned coil packs and plugs everything ok now cheers all for your help
Quote from: stu24v on 05 December 2016, 19:09:48
Good news.
Did you find oil or water in the plug wells? If so you need to seal the cam-covers or scuttle (or both) to prevent re-occurance.
stu24v
powerslinky
If you found oil in plug wells it means cam cover gasket/s  have failed & will need replacing. If not it will just re occur rather rapidly.
If you found water there , the scuttle needs looking at to prevent this happening again. ;)
