LED bulbs.
Started by Field Marshal Dr. Opti, 03 December 2016, 20:21:21
In this instance GU10 for around £3.50
According to the box it gives 50w of illumination but requires only 5w of energy.
Supposedly it will last 23 years. ::) ::) I won't hold my breath.
Varche
Keep the receipt. One of the biggest cons out.
Buy two similar bulbs for matching lights and one lasts four years and the other four months. Can you find a match? No, can you find the receipt? No.
TD
For GU10 led's I have found these to be very good
https://www.amazon.co.uk/Pack-MiniSun-Thermal-Plastic-Replacement/dp/B00RXHOUG8/ref=sr_1_2?s=lighting&ie=UTF8&qid=1480840096&sr=1-2&keywords=minisun
I also have Minisun golfball leds in all my other fittings as well.
I make sure they are 5W and 450LM and my preference of warm white  :y
Gaffers
Switched to LED bulbs years ago and  other had any issues.
Quote from: Guffer on 04 December 2016, 08:51:19
Snap. Had Halogen ones in bathrooms and kitchen, always failing. Expensive, for some reason lights here took a specifc type. £10 a shot. AU GUF 11/64.
Switched to GU 11s, in some case had to cut the frame thing off the holder so they would fit. But had zero issues, a year later nothing has blown. Instant fire up of light, run cooler and cheaper.
Win Win!
Mr Gav
I bought THESE last year for the kitchen as the halogen bulbs were forever blowing, not had an issue since, granted it`s only been a year but I would have had to replace all four halogen bulbs by now.
biggriffin
Hoof'land storeman.
Quote from: Varche on 03 December 2016, 20:37:54
How is that any different to incandescent bulbs? Especially modern ones, which don't last very long at all.
Quote from: TD on 04 December 2016, 08:36:34
Just ordered 4 of these. :y
Quote from: Mr Gav on 04 December 2016, 09:13:57
Two quid a piece. If I'd needed ten these would have been worth a punt.
The key with LED bulbs is to buy the branded ones, which will cost more.
The LED types used are a bit like diamonds - there are various grades, affecting both colour and life.  The branded ones like OSRAM will use the higher grade ones.  The cheap shite ones that you'll pick up from likes of egay are the LED equivalent of tool grade diamonds, and have a short life before their light output is unusable.
TD
Quote from: Doctor Opti on 04 December 2016, 13:25:32
Ive had these for about a year now, still fine, but the warm white variety...not the cool white that these are  :y
I think you'll be quite impressed how bright they are  :)
Quote from: TheBoy on 04 December 2016, 14:35:43
Perhaps.....maybe......do they f*ck. ;)
I've bought plenty of branded items that have lasted barely five minutes.
Often they just use  'a trusted brand' and link it to poor quality goods......like BUSH.
tidla
ledhut, 5yr guarantee. Fitted to my home and commercial. non packed up yet.
Plus theres the ocasional piccy of Sarah beenie
Quote from: tidla on 04 December 2016, 18:31:50
......and breathe. :D ;D
