Wanted: Ignition barrel
Started by Shackeng, 16 December 2016, 16:06:49
Shackeng
As above, I guess they are all the same. This is for my TD. :y
Diamond Black Geezer
Might be able to get you a cheap one tomorrow morn? (off to see a scrapper, might be able to grab you it for beer money off the bloke)
Of course the 'rebuild it with new sliders' option is there, too.
If you fear getting stuck unable to turn the key in the middle of nowhere, then in the short term, remove some of the troublesome sliders, a car thief can't exactly tell from the outside that you've done it.  :)
Shackeng
Quote from: Diamond Black Geezer on 16 December 2016, 16:25:02
Cheers DBG, no problem with the sliders as they were replaced not long ago, and will be refitted to a replacement barrel. The retaining latch on mine is broken, and it is held in by a very small roll pin in a blind hole, so probably not replaceable, and in any case would have to come off another barrel.
Someone may have one in their 'parts store', if not I'll let you know. Thanks very much. :y
Pauls might have one... Sure there was one in the ecu etc he had of me a while back :-\
Shackeng
Quote from: Doctor Gollum on 16 December 2016, 17:13:57
:y :y :y
