2.5 automatic abs ecu wanted
Started by cam.in.head, 22 December 2016, 14:18:27
cam.in.head
hi there to everyone. just joined this forum after reading many usefull post over the last few months.i am a long standing vauxhall fan and aquired an omega last year myself although my brother has had one from nearly new. it is for his car that we now seek a replacement abs ecu.it had the abs/tc/speedo issue and his ecu has been condemned by ecu testing as unrepairable.does anyone have a refurbed bba or other unit?.even a unworking one that can be sent off. its for a x reg 2.5 automatic. number 0 273 004 206. many thanks. chris........
cam.in.head
thankyou. went to that link but he doesn't have one. cheers.
cam.in.head
Hi. I assume it must be for an auto as well as the correct ecu number ?
omegod
I've got a couple but can't remember which came from which car I broke, do you have the part numbers off your ?
cam.in.head
Yes its 0 273 004 206 and is for a 2.5 automatic. Thanks.
cam.in.head
Ive been offered one that has the correct part number.DX on the pump ,which i wont be using anyway and last numbers 206 on ecu. Trouble is its from a manual car. WHAT will actually happen if i put this on. Ive heard abs will be fine but tc wont ? Has anyone tried this? .also i may have a chance of one from a 3.0 auto. Same number and same pump DX.same age.or can a 206 unit be re proggrammed correct ? . Many thanks.
If the numbers match, it should be fine. Any behavioural issues will able to be addressed with a quick tech 2 session.
I suspect that the auto/manual difference will be in the loom rather than with the ecu ;)
cam.in.head
Ok thanks for that. The guy in the yard says the abs & tc lights were on so it is probably faulty anyway but i intended to send one to bba anyway because of the imminent failure design built in !
Quote from: cam.in.head on 11 January 2017, 12:49:34
You might get lucky, a duff sensor should put the lights on...
cam.in.head
I will check continuity of the sensors on mine too just to be sure. At the abs plug.
Quote from: Doctor Gollum on 11 January 2017, 13:15:57
Of course, you have more chances of pulling your foreskin up over your head to keep your ears warm. We know it will be a shagged ECU.  But I admire a bit of optimism ;D
