NCDC 2013 removal
Started by tigers_gonads, 24 December 2016, 10:37:57
tigers_gonads
Quote from: Doctor Gollum on 26 December 2016, 20:28:47
Haynes is pretty handy when it comes to the MID wiring :y
I've got a old pre face one here
Can't see the wiring been any different for the MID  :-\
Cheers Al  :)
MID is almost a straight swap for a CID - you just need to run the wires for the stalk buttons.
tigers_gonads
Quote from: TheBoy on 27 December 2016, 10:04:01
I think I have a stork off one of my many estates somewhere  :-\
I take it that the pre facelift ones are the same ?
Depends on features on the stalk, namely there is a difference between saloon and estate (for rear wiper) and if it has variable wiper speed.
tigers_gonads
Quote from: TheBoy on 27 December 2016, 11:00:21
The last 3 Omegas i've had have been estates so should be in luck hopefully.
Variable wiper speed ..........
Looks like i'm going to be living in the maintenance / FAQ section for a bit  ;D
Cheers TB  :)
Quote from: tigers_gonads on 27 December 2016, 10:54:08
Plug might be different, and may have variable wiper wheel, but as long as it's an estate one, then you should be fine.
Mid needs to be a later one though as early ones had different plugs ;)
tigers_gonads
Okay, lost the permanent 12 volts feed to the head unit  ::)
Before I run a fused cable from the battery (which would be better I know) , what's the fuse number for the permanent live ?
Also found out that the units chassis MUST BE Earthed  ::)
No if or buts  ::)
One day, I will read the friggin manual  :-[
Quote from: tigers_gonads on 27 December 2016, 15:14:07
No if or buts  ::)
Permanent live is the thicker red wire, switched is the thinner black one... typically on opposite pins to after market head units :y
tigers_gonads
Quote from: Doctor Gollum on 27 December 2016, 15:50:26
No if or buts  ::)
Permanent live on the car loom Al
Its died on me  :(
Looking for the fuse  :-[
Dash conversion kit came with a new harness so should be plug and play.
I've checked fuse 6 as per the guides
On my fusebox, its missing but fuse 7 (20 amp) powers the switched live / interior light / services  :-\
I'm beginning to wonder if somebody has been playing around in there before I bought the car because its not the first time i've had fun like this  :(
Ah ok, that'll help... not ::)
Have you tried a fresh fuse in 6? box is colour coded, but 10a iirc...
tigers_gonads
Quote from: Doctor Gollum on 27 December 2016, 16:17:26
Yes  :y
20 amp on the facelifts  ;)
Oh 'dangle berries' to it, i'm off down the pub for a couple of hours before I get too pished off with the thing and do something silly  ;D
I'll jump in tomorrow Al when I have a clear head  :y
Thanks bud  :)
tigers_gonads
Before I do pish off  ;D
The Alpine loom has 3 wires for the steering wheel controls ..............
Brown / yellow   remote cont In 1
Brown / Orange   remote cont In 2
Black    remote cont ground
How does this little lot connect up to the miggy ??
Best I go now  ;D ;D
TTFN
Quote from: tigers_gonads on 27 December 2016, 17:05:30
Best I go now  ;D ;D
TTFN
It probably won't without a separate adapter, should Alpine even make one.
tigers_gonads
Got one of these .............
  http://www.ebay.co.uk/itm/Autoleads-SWI-CP2-VX21-steering-wheel-interface-Vauxhall-resistive-analog-ISO-/351902835667?hash=item51ef0b23d3:g:n2QAAOSwa~BYRTcZ
From Halfrauds but knowing the manager I didn't pay half of that  ;) ;)
Right, sup coffee and back out into the cold  ;D ;D
Thanks lads  :)
