NCDC 2013 removal
Started by tigers_gonads, 24 December 2016, 10:37:57
tigers_gonads
Quote from: RobG on 02 February 2017, 17:01:08
90493283  62 38 540 RELAY, INTERMITTENT WINDSCREEN WIPER   (C) R1000001-  T1000199
90494187  12 38 526 RELAY, INTERMITTENT WINDSCREEN WIPER   (C) T1000200-  X1999999
http://oldsite.omegaowners.com//forum/YaBB.pl?num=1176542235
Okay, i've got a shed full of relays but many different colours and numbers  ::)
Did these numbers ever change because I cant see one with any of the 2 numbers supplied by Rob  :(
What colour am I looking for ?
Sorry, bad hair day  :( :-[
tigers_gonads
The one fitted to the car is yellow Rob
Could it be that the car already has one fitted and just needed the variable stork ?
I've got a box here full of relays from 3 pfl estates and not one yellow one  :-\
Have you fitted the variable speed stalk?
tigers_gonads
#64
Quote from: RobG on 03 February 2017, 19:44:46
Fitted, not wired.
Just need to cut the black / yellow on pin J and splice in the 2 from the stork
The cars been at the other end of the street all day due to workman so couldn't get a soldering iron out to it  :(
tigers_gonads
Quote from: RobG on 03 February 2017, 20:15:00
Once wired, should be ok
I'll report back in morning  :y
Thanks Rob  :)
tigers_gonads
Variable wash / wipe modification now sorted  :y
Thanks to all concerned  :)
As for the MID installation, even though the extended wiring is routed behind the dash ready, sadly due to my eye sight not as good as it used to be and my new contact lenses / reading glasses not here yet, I can't make out the pins properly and can I hell as find the Brown with red trace  >:(  so it looks like dodgy eye sight stops play  >:( >:(
I'll leave the dash in pieces for now until I can get this sorted  :(
Thanks all  :)
The dash should contain all the wires in the loom, but they can be taped up as dead ends short of the plugs. Certainly had to root around when I fitted the MID to the plod bus...
Coming from a CID to a MID it should all be there... did I send you the map?
tigers_gonads
Quote from: Doctor Gollum on 04 February 2017, 11:25:48
As in just the wires / no plug  ::)
Probably why I can't find the foooker because i've been looking for a lump in the looms were the plug would be  ::)
I'll untape some more around the steering column end and have another look  ;)
As for map ??
Nup, i've done it all off the guide and info in this tread  ;)
Couldn't remember if I had sent you the diagrams or not...
Will rectify later.
tigers_gonads
Quote from: Doctor Gollum on 04 February 2017, 19:05:50
PM incoming :y
And received mate  :y
A bit weird though ...............  I can open the attachments through my email address on my iPhone but it wont open on the laptop  :(
I'll have a play (or more likely, ill get the lad to fathom it out for me) later  ;D
Cheers Bud  :)
tigers_gonads
Quote from: Doctor Gollum on 05 February 2017, 14:35:31
Try again :y
Nah, won't open individually but I can just see them if I open your downloads folder and press slideshow.
Got to read quick though and cocking my head over on one side makes me look like a cock (I await the abuse  :D)
I'll make it work
Cheers Al  :)
