Omega Buyers Guide?
Started by anV6, 28 December 2016, 11:44:10
anV6
Quote from: Zirfeld on 08 January 2017, 19:43:23
Hi anV6
Here are some pictures of the Bitter Monaro. The pics are taken on a Freiburg industrial area. I knew the place, so I am sure that is no fake. The car was offered for 19500 €
Not so bad.
Pontiac GTOs imported via Bremerhaven  are (included toll and license) in the same range. But without history.
Kostenloses Bilderhosting
I must say I like the way the Bitter looks better than the GTO. It must be a real mind twist in the autobahn when people see it.  :)
Do you know how many Bitter converted?
€19000 is indeed around the going price for a GTO. I would rather pay that for the Bitter because of the history as you say.
Fraggles Rock
Some correction is needed here...
That is an imported GTO... the Monaro/GTOs were all built in Australia. Eric Bitter bought an early production car from the Holden factory and made some detailed changes, the wheels being most obvious. It never made 'production'...
https://en.m.wikipedia.org/wiki/Bitter_Cars
Also confimed in this Australian article about the Holden VE Caprice...
http://www.carsguide.com.au/car-news/bitter-looks-sweet-15296
The Gto version was lightly reworked for US regulations, but was launched in late 2003 for the 2004 model year,which confirms the Bitter SC11 as an early production car having been displayed in autumn 2003.
HTH ;)
Zirfeld
#227
Hi Fraggle Rock
That is not an imported GTO. It is an imported Holden. You can see it on the gasoline tank position. Holdens fill ins are in Omega position, the GTOs have their fill in high underneath the end of "C" pillar, because the tank is behind the backseats.
So Bitter did not only detailed changes. He converted a Holden into LHD and brought the car through the German law of licence. Also he created different front designs.
Sadly only a handful cars where build....
Rolf
I am not forced to drive an old Omega. I simply like it.
Fraggles Rock
ALL early Monaro Coupes, including the earliest pre production Gtos from 2001 to 2004 had the fuel tank under the boot floor as per the Omega. 2005-2007 My, ie end of production, have the filler in the C pillar coupled with a smaller boot and the tank behind the rear seat.
As a rule of thumb, 5.7 cars have the boot floor tank and 6.0 cars have the rear seat tank and relocated filler all. Looks like the final production 5.7s jumped the gun on moving the fuel tank for type approval reasons.
The only place those lhd Monaros could have come from is the Holden factory. The Monaro had a variety of production front ends, of which the example you posted looks pretty stock :-\
anV6
Is it difficult to get the cruise control to work? I have looked at a couple of cars which were converted from automatic to manual and the sellers said cruise control no longer work after the conversion. Something to do with it being programmed for an automatic or whatever was the explanation.  Is it difficult to put it right?
Crappoy excuses for lazy work... requires a clutch switch and some loom... much easier to fit at the time than to mess around with after as the wiring can be done before the clutch is fitted ::)
anV6
I thought the manual transmission shouldn't be the excuse as I have had several manual cars with cruise control.
But I guess to do it now after everything is in I'm looking at quite a bit of work then?
Answered in my last post ::)
Zirfeld
Hi an V6
As gollum says, you need a clutch switch. Most Opel Omegas are pre cabled for ride control use. For further details look for Kurt`s "Tempomat" postings (opel-voting.de)
Rolf
anV6
Quote from: Doctor Gollum on 11 January 2017, 12:02:30
You said what needs to be done. I was asking how much work it is?  ;)
Have you done the job?
anV6
Quote from: Zirfeld on 11 January 2017, 14:42:16
Hi an V6
Rolf
Thanks Rolf! I will see if I find it. Never heard of the forum either, so it's good to know about it. But my German skills are very unimpressive.  :(
zirk
Quote from: anV6 on 11 January 2017, 16:12:44
Everything you need to know is in the OOF Guides, search for it.
anV6
Quote from: zirk on 11 January 2017, 17:40:45
Do you mean the FAQ? I didn't see it there.
henryd
Quote from: anV6 on 11 January 2017, 18:59:54
http://www.omegaowners.com/forum/index.php?topic=90592.0
other rides
zirk
SEARCH for it, Im not doing it for you.  ::)
