Warning buzzer for leaving your lights on
Started by robbo2345, 29 December 2016, 17:20:20
robbo2345
Hi guys can anyone tell me if the buzzer that sounds when you get out of the car and have left your headlights on is located ? I thought but have no real idea that it was part of the headlight switch . Asking as mine does not sound and having recently flattened the battery after driving In fog during the day locked the car and went shopping for 5 hours and came back to a flat battery . :(
life is too short ...... so live it every day !!
robbo2345
Thanks Rob presumably just replace the relay and job done ! :y
steve6367
Quote from: robbo2345 on 29 December 2016, 17:20:20
Is the door switch working? Last time I had this issue it was that - remember it a double contact type when testing.
robbo2345
Is that the plunger type on the pillar if so I guess no as when the drivers door is opened the courtesy lights do not come on !
Quote from: robbo2345 on 29 December 2016, 19:51:04
Probably a good place to start then ;D
steve6367
That is your problem then - easy to change  :y
remember that the driver's door is a double contact switch rather than single like the rest
robbo2345
Thanks guys I guess I need to post on the parts wanted now lol  :y unless  ;)
