Just done my throtle body & breathers.....
Started by Colin G, 07 January 2017, 14:52:36
Colin G
when I took the throttle body off the manifold I noticed that there was quite a bit if moisture at the bottom when looking down into the opening - it didn't smell like petrol so presume it's coolant?  Is this normal or am I looking at another problem?
Given the weather, probably condensation unless you have alot of other symptoms ;)
frostbite
It will be oil. I get the same, when I clean out the TB I spray carb cleaner into the manifold then soak it up with blueroll with my 4 prong reachy thing
e46 325i se - 1.8vvti avensis liftback
Colin G
Must admit, engine seems to have a bit better low end response now  :)
