One for the BMW haters- fill yer boots!
Started by Viral_Jim, 11 January 2017, 15:59:21
Quote from: Doctor Gollum on 01 March 2017, 16:45:01
The new 5 series looks nice...
Not quite as nice when you've bolted one of these to the roof just in case...  ::)
Quote from: Kevin Wood on 01 March 2017, 16:51:54
That won't work if the power goes... need batteries :D
I don't recall an issue with the charge in the battery, just that the shite firmware wouldn't let any of it out. ;D
Provisionally sounds like a good result. :y
The world of exciting motoring options is opening up for you once again. :y
Viral_Jim
They do. I had thought about that, but for my budget it'd be a 2.0d bones-of-yer-ar$e spec. And the 3 series doesn't appeal.
Quote from: Doctor Opti on 01 March 2017, 17:02:22
Indeed so. However a potential new job and 25-30k miles/yr closes those options again! Were it to come off I would have to go for a sensible daily and a weekend toy.
Until matters resolve, I shall stay in the trusty Desmond for a little while.
Quote from: jimmy944 on 01 March 2017, 20:25:55
Are you sure that a derv purchase is wise? ::)
X30XE
Quote from: Doctor Opti on 01 March 2017, 20:40:19
Yeh cos the fact it's diesel is the main reason not to buy a new BM  ::)
Omegatitis : [in remission]
Viral_Jim
I'm not sure if it will be derv tbh. But I need something that will crack 35mpg. And I genuinely prefer diesel to small (<2L) wheezy naturally aspirated petrols. Particularly as I favour 2 pedals over 3.
What the BMW did make me realise is that day to day performance isn't really important. Hence my idea to split.
I'm tempted by another Saab 9-5 aero, but that would have to be a manual :/
Hardly the most reliable car if you intend using it to travel 25000 miles a year for work.
Viral_Jim
Quote from: STEMO on 01 March 2017, 22:15:17
Really? The previous 2 I have had I ran from 60k-90k and 150-175k. In that time one had a wheel bearing and the other a coil pack. Beyond that it was  pads, oil and filters.
All could well be moot if the job doesn't come off in which case I'm thinking 6-8cylinders. Probably a Jaaaag. :)
Both of them barely did a year's worth then :)
Viral_Jim
Well if you're going to put it like that :P
Look after it and the Omega will get the job done indefinitely  :y
