Project advice
Started by Fraggles Rock, 13 January 2017, 19:12:45
Fraggles Rock
Right, have found a car which should fit the bill... It's a manual estate, with MoT but needs some love...
Good points, it's a Cdx, so I guess that's a pretty good basis for adding goodies like heated rear seats as it already has a sunroof and Xenons... Also, am I right in thinking that it won't have self levelling suspension, which will make it more straightforward for firming up:-\
OK bits... MoT is only until the spring, it doesn't look too shabby. It's done around 130k... It's a 2.2 petrol, so whilst it won't set the world alight, it will go ok, and will be the most straightforward to upgrade... Will cross this bridge later.
Bad bits...
The interior looks like a bomb has hit it, and although the body work is generally ok, it clearly has some rust growing on the osr quarter... Expecting to find a hole behind the bumper trim, although this shouldn't be a big issue to fix :-\
Have asked the seller a few questions before I go and see it...
Only things difficult to retrofit into CDX are the cabin looms for full memory functions and Bose.
Not sure how easy a 2.2 to v6 engine swap would be, if any cabin looms needed, could be tricky. I suspect retrofitting any v6 goodies like servotronic will be a pain, and I bet you will have to replace the entire ABS unit due to TC, and the other ECUs will expect to see a TC ABS unit.  Dash clocks and MID will also need replacing.
zirk
No offence, but, wouldn't have been easier to get hold of a 3.2 MV6 or Elite Estate and convert it to manual, if that is what your after?
anV6
Quote from: zirk on 14 January 2017, 13:17:33
And...here...we...go. ;D
Fraggles Rock
I'll start at the beginning...
Quote from: anV6 on 14 January 2017, 15:31:40
I actually know exactly what I want...
And to address Zirk and TheBoy...
Drivers seat will still have memory, cosmetically, it only requires a spoiler and wheels.
As for the rest, I'm not looking for a V6 end result, want to go down the blown 4 pot route. TC might simply be an ecu swap, but not worried about that at this stage. Equally, not fussed about servotronic as the 2.2 has nicely weighted steering, especially with the Sport chassis... it's a preference thing ;)
Equally, whilst Bose is nice, thinking CCRT2008. Heated rear seats and reversing sensors would finish it off.
anV6
Quote from: Fraggles Rock on 14 January 2017, 17:13:34
I think either you misunderstood my reply or I'm misunderstanding yours. ???
ronnyd
Doesn,t your profile state "at least 6 cylinders" ;)
Fraggles Rock
Quote from: ronnyd on 14 January 2017, 18:53:19
Nope...
ronnyd
Quote from: Fraggles Rock on 14 January 2017, 19:08:24
Nope...
Not now anyway :D
That's why I said full memory ;), which if more than one driver, is surprisingly useful
Sorry, my bad, assumed v6.  The issues still apply, but sure you can overcome if seriously prepared to put in a non standard donkey.  Likely you'll never get fuel computer working though...
The standard audio is a bit wanting TBH. You may see improvements with decent aftermarket speakers, but the standard HU's don't have great amps built in.
Heated seats are very trivial - less than 30mins. Rear sensors also not too taxing, but worth getting a pic of factory bumper locations. The factory Bosch system is a million times better than cheapo egay tat.
Fraggles Rock
Full memory isn't impossible, it's only wiring... but as the only driver, can't see it being a big deal. Besides, if anyone else driving it is unable or unwilling to adjust the mirrors themselves, I will gladly do it for them  :D
Agreed re the rear seats/parking sensors. Both pretty much plug and play.
The idea being to get a nice daily driver just right, be easier to sort the engine side of things with the car on the drive, especially from a willitfit perspective, and with a modest MoT on the proposed car, makes sense to get it up together and through the next Mot, leaving the summer to ponder the engine options ;)
Fraggles Rock
Been having a root around and have had and idea or two re the engine...
Firstly, the supercharger route is probably out... the Z20NET engine won't fit the Omega gearbox, which, when coupled with the plumbing and mounting considerations, rules that out... be a good way to reinvigorate a 2.2 Vectra C though 8)
However, the Z20LEx engine will fit the Omega, and as near as can be seen on tinternet, the head and head gaskets as fundamentally the same as the Y22XE. Can anyone confirm?
So, thinking: fit Z20LEx head and manifolds from a 2001-5 Astra/Zafira GSI along with loom and ecu to the Omega block. If at some point more power is needed, then the various bits from the later Astra VXR all bolt on, and if the block has a fit, it too can be replaced or rebuilt as required. All rounded off with a nice stainless exhaust...
