Omega booked in for the dyno
Started by Webby the Bear, 14 January 2017, 17:36:39
Webby the Bear
Hi boys. Not been around for a while as I mentioned last time works so busy.
So got the old girl booked in with Northampton Motorsport for two weeks time. Someone on here recommended them so thanks for that.
I've spoken to them and they've assured me they can dyno test it being an auto box no problem. So out of interest how will they do this without a tech2? Well, that said they may have one who knows.
Anyways..... predictions.....  ;D
RIP Paul Lovejoy
165 bhp and about 195lb/ft, oh and about 9.5 seconds :D
Edited, as I forget it's actually a 2.5 ::)
Webby the Bear
Ps to add re the history of the motor....
It's clicked over (today coincidentally) to 117k miles. I got it with 69k in 09 on the clock and an unknown service history. Ever since then its had oil changes every 3-5k. All other items serviced every 6 months or so.
Sometime ago TB drove it and said it was a bit underpowered. I then found a fault with the multi ram that I fixed. I then started driving it a lot harder and the gearbox drops a cog at will now.
I then took it to serek who thought it was "quite nippy" for an omega.
I've tested compression and all cylinders are within spec. I've done vacuum tests and not a hint of exhaust blockage or anything untoward.
To tell the truth the only issues I've had in the last few years is cam cover gaskets.
RIP Paul Lovejoy
Webby the Bear
Quote from: Doctor Gollum on 14 January 2017, 17:39:38
135 bhp and about 165lb/ft, oh and about 10.5 seconds :D
After doing quite a bit of research on this I think you're about right  :y
Pray tell though why you think that. Bearing in mind that it had 170 out of the factory
RIP Paul Lovejoy
Quote from: Webby the Bear on 14 January 2017, 17:47:06
See above  :-[
:D
Webby the Bear
Quote from: Doctor Gollum on 14 January 2017, 17:48:10
See above  :-[
:D
lol I'm thinking you were closer with your first answer  ;D
But we will see. Out of interest have we seen any other non modified autos on the dyno, results etc? I can't be the first nutcase to take their slow unmodded sh*t box to the dyno..... can I?  ;D ;D ;D
RIP Paul Lovejoy
The dyno measures the power at the wheels. Vauxhall's figure is at the flywheel. There's a big difference! And 40hp loss from a well-used automatic transmission (and the rest of the drivetrain) would be reasonable.
While you're there, get them to show you what other cars make on the same machine, as a single figure won't tell you anything useful.
Webby the Bear
Quote from: Nick W on 14 January 2017, 17:55:55
Will do nick cheers  :y
Did Vauxhall ever give a figure at the wheels as I couldn't find one?
RIP Paul Lovejoy
Quote from: Webby the Bear on 14 January 2017, 17:59:22
I doubt it. Why would anyone care? ;)  Especially as they don't publish the torque curve, which would actually be of some use.
Webby the Bear
Yeah I couldn't find it anywhere.
If you had to guess (to give me some basis) what do you think would have been the HP at the wheels from a brand new 2.5?
RIP Paul Lovejoy
biggriffin
Before you take it, give it a service, plugsx6 new air filter, New fuel filter, oil change and filter, and new leads., clean throttle bodies, gearbox oil change,  should do.
Hoof'land storeman.
Webby the Bear
Quote from: biggriffin on 14 January 2017, 19:25:23
Well ahead of you bg lol all done last week. Well, except the gearbox fluid. But did that 6 months ago.  :y
RIP Paul Lovejoy
Webby the Bear
Quote from: serek on 14 January 2017, 19:38:19
If you can wait few weeks will come with you
Yeah I can rearrange mate. Pm me your number cos my phone broke last night and I got no numbers at all  :'(
RIP Paul Lovejoy
Webby the Bear
Ps is EMD still on the forum? Could get Martin and steve up and we can all laugh when my car blows up on the dyno all celebrate when it produces over 300hp  :y
RIP Paul Lovejoy
