Renewing ignition tumblers
Started by Viral_Jim, 16 January 2017, 15:53:57
Viral_Jim
so, with the issue with my Bimmer not being resolved, it looks more and more likely that I'll be back in the mig, at least temporarily and possibly for a year or two while I decide what to do next. To that end, I need to fix a few of the niggles that I wasn't going to bother with if I was getting shot of it.
One of those niggles is the ignition getting stuck as the key won't turn. I understand this is due to wear on the tumblers meaning they don't dis-engage properly from the ignition barrel. Question is, where can I source new ones? Alternatively, can I just file/grind the lobes off the tumblers so they disengage from the barrel?
I know technically the second option means you could start the car with a spoon, but seeing as its got an immobiliser I'm not too worried about that! I don't want to fit a separate barrel and lock as I want the doors to work off the same key.
Worth having a look here, including my postscript at the bottom.
http://www.omegaowners.com/forum/index.php?topic=90600.0
Take out each lever and give it a quick clean, de-burr and lube with some graphite, then check the "sprung pin" and the track it runs in and it will be fine for years. :y
Shackeng
Viral_Jim
Thanks chaps, looks like a fairly straightforward (if fiddly) one to go on the list  :y
Shackeng
Quote from: jimmy944 on 17 January 2017, 08:42:16
Due to an ignition switch and barrel change, I recently fitted mine in the new barrel to retain the same key. it really is a very simple job. Just follow the excellent guide, and do not lose the springs. :y
Quote from: Shackeng on 17 January 2017, 10:51:19
Yes, take it apart in a plastic bag. I read the bit in the guide about being careful and still launched bits all over the place!
terry paget
Quote from: Kevin Wood on 17 January 2017, 11:09:23
I've done that too, most annoying. It's a satisfying job, done indoors once you have removed the lock and barrel from the car. The error I made was to remove the key from the lock cylinder without having my hand around it, allowing the springs to shoot the tumblers all over the carpet.
Shackeng
Quote from: terry paget on 17 January 2017, 18:04:53
Probably the most crucial bit! :y
