Vectra estate ?
Started by EMD, 25 January 2017, 21:42:34
EMD
Been thinking about a 2004 VAUXHALL VECTRA 3.2i V6 Elite Auto . I presume the v6 in this one is totally different from the omega  :-\ Looks good value for money and in near mint condition .
So any pitfalls to know about ?  :)
Its not the omega replacement , just a second car .
Omegatitis
Same engine, just fitted transversely with a different inlet etc setup.
Mr.OmegaMan
Doing the cam-belt, water pump etc.. will probably be more challenging.
Definitely a good work horse the Vectra C estate they are huge! Especially now their cheap. Would still take an Omega estate over one in a heartbeat, but it's as close as you'll get a Omega 3.2 estate in that price range. They seem to be reliable enough also. Being a Vauxhall parts will be reasonable etc..
Same engine but slightly different inlet. Vectra C estate gives an Omega a run for it's money with much better rear legroom.
anV6
Horrible understeering! The 4 pots are weaker but at least don't like to dance out of the road.
2boxerdogs
A lot of car for the money , have seen a few nice ones go very cheap don't think you can go wrong.
minifreek
The 3.0 V6 DERV is the better engine to go for in the Vectra's.....
D.I.L.L.I.G.A.F...
Quote from: anV6 on 25 January 2017, 23:45:08
Utter rubbish. Even the 1.8 can be made to lift off oversteer on demand :D
Quote from: Doctor Gollum on 26 January 2017, 07:13:32
Very easily too ::)
I had a 2 litre oil burner and that would oversteer on lift off with great ease... Always good fun with an unsuspecting passenger ::) :D
I could be wrong but I believe the Vectra estate shares it's floorpan with the Signum.
Plenty of rear legroom in the Signum. :y
Quote from: Doctor Opti on 26 January 2017, 12:11:31
It does and there is. ;)
anV6
Go into a good bend and try to have some fun with the gas and see how that goes. The Vectra C V6 has one of the worst cases of understeering of any FWD car I have ever driven.
Clearly can't drive then :-X
2boxerdogs
anV6
Quote from: Doctor Gollum on 26 January 2017, 13:49:48
Oh yes, that is an easy way out of an argument to which you can't present any valid points. ::)
I have driven a Vectra C V6 on a track. Have you? It doesn't even matter if it's controllable, easy to counter or whatever. My point was it's there and in loads.
If I cared enough for your opinion I would go hunt for the top gear episode where Clarkson also finds the same thing out when testing a Vectra C. But I honestly don't. So enjoy your Vectra. :y
