CDR2005
Started by Pmacca2000, 27 January 2017, 18:38:38
Pmacca2000
Over the past year or so I've become unable to play CDs in the car, added to this the display no longer shows radio station but the date or a blank space.
Id like to keep the car original and was wondering about getting the stereo serviced ?
Pmacca, living the dream since 1995
Do you play homemade cds?
Pmacca2000
No in fairness I could intermittently play proper CDs but over the past year you can put them in but nothing happens.
Be looking for a new unit then :'(
Lots of second hand units on ebay for £20 - just need to make sure that you get one with the code that hasn't been used to play cds............
Pmacca2000
 Cheers Andy,
I was wondering about getting this unit serviced as it keeps the car original if that's a possibility?
If you can get the parts...
This...
http://www.omegaowners.com/forum/index.php?topic=127181.0 will give you an idea of what's involved... ;)
Pmacca2000
Cheers for that, I understood the units were all shaped in a different was to stop them getting nicked, is that not the case ?
The facia panel is the difference... box behind is essentially double din sized ;)
Pmacca2000
So just one out and one in?
Maybe cheaper than a referb of the current unit
As Andy says :y
So yes, but make sure that you get the code with it...
Dave DND
No problems in refurbing that unit if you want to keep it all original
Which version have you got?
Delco  or  SiemensVDO  or VDO ?   (all use different parts inside - but most kept in stock)
http://www.dndservices.co.uk/in-car-entertainment-repair-service.html
Radio & Decoding Technician
Pmacca2000
I think it said VDO 2005, I'll check though as sad as it sounds I'd like to keep her accurate to the build order
Dave DND
No problems with spares for that one - send it over and I can take a look for you   8)
polilara
Quote from: Dave DND on 30 January 2017, 10:44:15
Hello Dave, If you have a Delco one in pieces could you have a possibility to check whether this chip TDA7313 is found there...
