Wim
Started by tooleater, 30 January 2017, 17:55:57
Reading the WIM forums, Im not sure Tony does anything day to day due to his health :(
Think he has only done my car once... But even the same operator has achieved two very different results. All depends how careful they are, and sadly you need to watch them to ensure the desired result... Saying you want XXX and only getting xxx isn't good enough, especially when the car is as finickety as the Omega :-\
Could always take your cars to Centre Gravity in Coventry.. but seeing as they usually maintain cars worth 400x the price of an Omega, don't expect to walk out with change from £400 ;)
The health check alone is £200, which includes:
Road test & report
Suspension test & report
Weight pre-load to spec
Tyre data check & adjust
Ride height check & report
Geometry check & report
Physical inspection of:
Dampers
Springs
Bushes & ball joints
Steering rack
ARB bushes & drop links
Tyre wear issues
Full setup would include:
Ride height
Camber
Caster
Toe
Bump & Rebound
Road test
From what they do you can tell they're used to working on things slightly more exotic than your average road car ;D  That said I know at least three people who've been there to have their cars set up - a 911 997.2, 911 997 w/ aftermarket suspension, Kirkham 427 S/C Cobra w/ original spec suspension and a BMW 645 w/ aftermarket suspension - and all of them rate the place very highly indeed.
Or throw £70 at the tyre place down the road and watch them like a hawk, as Al says.
wheels-inmotion
Quote from: Jimbob on 02 February 2017, 07:25:04
That is somewhat true i'm sorry to say. Nevertheless i'm 10 miles and a phone call away if needed. I do however pop in and pull geometry reports from the machine to ensure standards remain and i attend any complaint if only to learn what and why it went wrong.
Quote from: wheels-inmotion on 02 February 2017, 09:10:06
That's good to hear Tony  :y
As I plan to bring my VW CC up to you guys when it needs new front boots and a geo setup.
wheels-inmotion
Quote from: tunnie on 02 February 2017, 13:30:55
They are quite adjustable actually, just be sure to contact me direct.
