Learned summat today (vw cam belt related)
Started by Webby the Bear, 02 February 2017, 20:30:12
Webby the Bear
Of late we haven't had many cam belts come in and to be honest I've been really enjoying repairs (suspension work mainly). However had a 1.9 pisshat in today and everyone had their jobs except me so I had to do it.
Firstly accesss to the belt is so easy. The crank pulley is easy with the 4 x multispline bolts. The aux tensioner easy to remove. Overall it was actually a joyful experience.
Anyway.
So with vw belts I've always found them tight as a nuns. So re the thing I learned..... I want to see if anyone knows the very simple trick to getting the belt on with no fuss at all. 1,000 Bear points on offer....................
RIP Paul Lovejoy
Shackeng
Is this the trick doing it with it running? I saw a clip of it somewhere. :y
Webby the Bear
No mate.  Prob should have explained better....
So old crank n cam locked off. New water pump fitted. New guide pulley fitted. New tensioner on its stud. There's something to do just before you put the new belt on that makes it easy to literally slap the belt on.
Note tat without doing this thing the belt will be stupidly tight to get
RIP Paul Lovejoy
Quote from: Shackeng on 02 February 2017, 20:42:00
I'd like to think that they really wouldn't try that with a customers car.
Webby the Bear
Ps just to add... this isn't me being all billy big shit  ;D I was struggling to get the belt on. And the new lad (who is ex Audi tech) said why aren't you doing it like this......and in 2 mins I was putting the covers back on......
Just curious if anyone else is aware of this  :y
RIP Paul Lovejoy
GastronomicKleptomaniac
Got to be a good thick coat of grease on the pulleys. :y
Ooh ooh. Remove the water pump and cast it aside?
Quote from: Webby the Bear on 02 February 2017, 20:50:48
We won't know unless you tell us.
Webby the Bear
Quote from: GastronomicKleptomaniac on 02 February 2017, 20:56:43
;D
Nope. Remember 1000 Bear points on offer  :)
RIP Paul Lovejoy
Webby the Bear
Quote from: GastronomicKleptomaniac on 02 February 2017, 20:57:02
Definitely closer than coating the pulleys in grease...
RIP Paul Lovejoy
Viral_Jim
I thought you just locked the tensioner with an Allen key, put the belt on then released the tensioner?  :-\
Webby the Bear
Quote from: jimmy944 on 02 February 2017, 21:00:27
We are getting warmer.  :y
When the belts on you turn tensioner with the (8mm) Allen so the pointer lines up with the marker. Then tighten tensioner nut.
But as said its before this to get the belt on.
But as you are getting warmer it's something to do with the tensioner  :y
RIP Paul Lovejoy
serek
Quote from: Webby the Bear on 02 February 2017, 21:11:38
you must seen this video then
https://www.youtube.com/watch?v=wGcttDoJy2I
YZ250
Thread the belt before fitting the tensioner.
