opps oppsety opps opps
Started by Doctor Gollum, 16 February 2017, 16:38:00
Of course  ::) and yup...  In that order :D
:(  All I get is a white page with "Photobucket" on it .. no piccies at all .. :(
X30XE
Quote from: Entwood on 16 February 2017, 20:41:45
As before; turn adblock off ;)
Omegatitis : [in remission]
Quote from: X30XE on 16 February 2017, 20:47:08
Tried that .. :(
EDIT
Disable adguard, reboot, piccie visible ... what a pain ...  :(
Bigron
I hope I'm not in egg-sucking territory here, but when using the two hammer approach, the non-hitting hammer needs to be substantially heavier than the hitting one: a "pop" is then virtually guaranteed!   :y 8)
Ron.
Quote from: Entwood on 16 February 2017, 20:47:56
Tried that .. :(
EDIT
Tell me about it... updated Photobucket is shite :(
Mr Gav
Quote from: Doctor Gollum on 16 February 2017, 21:47:26
Tried that .. :(
EDIT
Yup...full of ads and takes forever to upload photo`s
Notch...
Confounded insert...
Bit big, but should be ad free ;)
henryd
Quote from: Doctor Gollum on 16 February 2017, 22:10:52
Notch...
Amazing that a plastic arch liner will do that although I've seen rubber pipes wear through steel ones which seems odd :-X
other rides
Obviously had a low level knock at some point, both lower arches being replaced with new ;)
Insert soaking over night, but be train to work :'(
The arms look damn near identical to the ones on my E64 with one exception - the balljoints are not tapered on the E64 and don't seem to go into inserts (in fact getting the nut off a non-tapered balljoint was the biggest pain in the arris on that job!)..
BTW I have started using imgbb.com instead of photobucket because the latter now only loads completely for me about one time in ten and somehow manages to hammer the CPU so hard (all the embedded ads and crap I guess) that the fans ramp up to max..
