Update on "The engine light came on".....
Started by Bigron, 26 February 2017, 17:36:54
Bigron
The engine light stayed on all the way back from Swanage to home, approx. 200 miles. Not a lot of opportunity to drive it hard with the M3 average speed restriction of 50 mph, and then queues from J12 to J28 of the M25 - for NO apparent reason!
Off to Halfords this afternoon and bought some Cataclean and added it right away as the tank was down 68 .litres from full, so a good concentration of Cataclean. Then the Italian tune-up to the nearest Shell garage (17 miles away) for some V-Power. The engine light was still on all the way, but after filling up and swithching back on - the light was out!
Well done Cataclean, and thanks gents for all your help.  :y 8)
Ron.
Migv6 le Frog Fan
It will come back on though.  ;)
only permanent solution is to move the lamdas.
BazaJT
Is this a 2.6/3.2 issue only?Or does it afflict others in the range?
Bigron
Thanks, Mig. How, and from where to where? Am I likely to be able to do it myself?
Ron.
powerslinky
#4
Quote from: Bigron on 26 February 2017, 18:16:00
Ron.
Have a look at the guide in maintenance section Ron. It is the  V6 petrol engine  section listed as "moving lamdas" I think . Unlikely you could do this yourself  . . Sereks your man  would say.
  Try a tank of premium unleaded with a good thrash  first , that often works  . . if only for a while.  ;) ;)
3.2's seem more prone to this O2 sensor problem than the 2.6's IMO . . . but it obviously does occur with the 2.6 as well  ::)
Bigron
Hi Al. Yes, after the Cataclean I filled up with Shell V-Power. Fair enough, I would certainly entrust the work to Serek, but do you have any idea what would happen if I did nothing? Apart from a frown from the MOT man, I mean!
Ron.
powerslinky
#6
Quote from: Bigron on 26 February 2017, 18:43:04
Ron.
as far as I know  . . .it won't affect the day to day running  . . .as you say just emmisions at MOT time i would think . But saying that my black 3.2 passed 2 MOTs with that problem . I just took the light off prior to the test with my cheapy code reader. It would return after around 7/800 miles though :'(
It impacts the 2.6 and 3.2 that spend too much time being driven like Miss Daisy.
powerslinky
Quote from: RumpelStiltSkin on 26 February 2017, 18:47:09
Ah right TB . . .that sums up my driving style perfectly ;D ;D ;D
Thought the 3.2's were more prone to this than the 2.6's though  :-\ :-\
Bigron
Ah yes - around town when I'm at home I AM Miss daisy, but the light came on after a good (swift) early morning run to Swanage and a few days of driving around Dorset.
Even when being a wuss at home, I do let it stretch its legs at least once a week on a run.....
Ron.
Quote from: Essex Big Al on 26 February 2017, 18:50:16
Obviously, at a Miss Daisy speed, the 3.2 is less pushed than a 2.6.
Quote from: Bigron on 26 February 2017, 18:51:51
Define, how much time does it spend above 4500rpm?
EMD
Ron.
Wont affect mot as long as emissions are within range . Mine has the eml on and it goes out by itself when it wants to  ::)
Omegatitis
pauls
Just get the lambas moved Serek does it in about 20mins job jobbed :y
EMD
Quote from: pauls on 26 February 2017, 19:23:50
Yes i was there when he moved some with markdtm , dont take long but im not going to bother ... ill just put a sticker over the light  ;D
Omegatitis
