Cheap Oil
Started by X30XE, 26 February 2017, 22:46:03
X30XE
Anyone know where I can procure some 15w40 should-be-dirt-cheap-unrefined-tractor oil for less than an arm and a dick?
Resent paying actual money for it when I only pay like 5p a litre for 10w40 semi from Vx  >:(
Omegatitis : [in remission]
zirk
I normally work on the basis that anything less than £2 a Litre for Semi or Full is reasonable, but if your getting it for 5p then Im buying it wrong.
Viral_Jim
Quote from: X30XE on 26 February 2017, 22:46:03
If you're that unconcerned about the quality, can't you just use the 10 40?
X30XE
Quote from: zirk on 27 February 2017, 18:31:44
Exactly, although Semi or Full should be much more expensive than mineral! Cant find 20L of 15w40 for less than £45 though.  Must be a price vs demand thing. No one's using it anymore.
X30XE
Quote from: jimmy944 on 27 February 2017, 18:36:59
Cold viscosity... it's for the prehistoric V8 me ol' china  :y
biggriffin
Quote from: X30XE on 27 February 2017, 18:39:41
10/40 full fat, is just as good, as cheap-O 20/50, viscosity wise., If your that concerned add some Wynn's.
Hoof'land storeman.
X30XE
Shouldn't be. That's the whole point of the viscosity rating.  The objective is to spend less money not more on snake oil  :P
If you have flat tappets and a soft cam will you be adding ZDDP? If not you'll want an oil with a high natural content, so that precludes dumping the cheapest stuff in there (and any Vx oils, I would imagine)..
X30XE
Quote from: aaronjb on 28 February 2017, 08:23:53
Nope.  Not particularly worried about cam wear. 100k miles and no maintenance from the last owner had done almost no damage to wear faces of the cam/tappets.
Just buy decent stuff yer tight Bastid!  :P  ;D
Viral_Jim
Ahh! makes a bit more sense now  8).
Although sir Tig does raise a good point :P
X30XE
Quote from: Sir Tigger QC on 28 February 2017, 10:16:35
Don't think there's any such thing as decent 15w40 mineral oil.  It's just unrefined dinosaur squeezings innit bruv.  Sure you can buy it in a tin can with a fake handpainted picture of a sports car on it... but it's still the same shit inside.  :P
alfie
 Got 8 lts of gtx on the top shelve of my garage,don't use it anymore,just don't want to bin it.
