Power steering
Started by Mr.OmegaMan, 04 March 2017, 00:02:47
Mr.OmegaMan
Anyone know the part number for the 2-pipelines that are visible in the front bumper when the bonnet is open if you know what I mean?
Seems the rust has won the battle and now there's a leak  ::)
Thanks in advance!  :y
polilara
I found one pic in my files. Are you talking about this?
https://gmpartsdb.com/genuine-part/24425991_5951728__pipe_pressure_steering_gear.html
Steering in right side?
Mr.OmegaMan
polilara
That number I do not have sorry to say. So your steering wheel is in left side?
Quote from: Mr.OmegaMan on 04 March 2017, 13:41:51
This one  :y
The site where you got that from has also got the exploded diagram for RH drive ;)
Mr.OmegaMan
Mr.OmegaMan
Quote from: RobG on 04 March 2017, 17:31:53
This one  :y
Couldn't find that picture on google again if my life depended on it  :-\
Mr.OmegaMan
Quote from: polilara on 04 March 2017, 16:49:14
No no... Mine is a RHD car (UK)... That image was the only thing I could find on google to try and explain which part I'm after.
Can't say I've seen any threads on OOF regarding this part before, Can't find anything in the search box either.
They do go rusty, think I've painted one of mine and smeared grease on the other (just carry on after you've put grease on the brake pipes!) My old DTi clearly had a similar problem as someone replaced the metal pipe with a rubber one.
Guessing it's going to be a dealer only part unless someone (Pirtek?) can make one up.
Quote from: VXL V6 on 04 March 2017, 18:19:47
Steering isn't a particularly high pressure system; so cut out  the rusty section of pipe, slip some suitable hose(sized correctly, oil and pressure resistant) over each end and add a hose clamp. Your local hydraulics/machinery supplier will have something appropriate.
polilara
Quote from: Mr.OmegaMan on 04 March 2017, 18:03:41
I think Your picture is from steering wheel in left side. I cannot enclosure figures here but if someone gives me personal e-mail address I can send a copy of right side steering where the number I proposed is from.
polilara
#11
Perhaps I succeeded to insert picture here. Is it part No. 3?
"Bensiinimoottorit ohjaus oikealla" means Petrol Engines RHD.
http://www.catcar.info/opel/?lang=en&l=bWFya2E9PVZYfHxzdD09MjB8fG1vZGVsdHlwZT09Vjk0fHxtY29kZT09VlhNfHxsYW5nPT1HQnx8c3RzPT17IjEwIjoiTW9kZWwiLCIyMCI6IlZhdXhoYWxsICBPTUVHQS1CICggMTk5NCAtICAyMDAzKSJ9
Mr.OmegaMan
These diagrams / charts / blue prints or whatever their called are just a load of jiberish to me, I'd greatly appreciate it if someone who knows the part number I require for the power steering piping . I've tried explaining to a VX / PSA dealer to no avail.
