Bore damage. Game over for BMW?
Started by JamesV6CDX, 10 March 2017, 17:59:04
Just doing final clean before refitting head hopefully tomorrow. Span the engine by hand to wipe the bores clean.
Found this.
Gutted doesn't come close to covering it.
JasonH
Nightmare.
Afraid I can't offer advice on how terminal that really is. Perhaps it'll just lose a tiny bit of oil and compression will be a bit down on that cylinder??
I'm more interested in how it's happened? I don't recall seeing it before but then I didn't inspect the bores, and this one was close to the top before I gently spun the engine by using a hand on the pulley
Is it something that I could have done having turned one rotation by hand? Or must it have been like it before!
You can't feel it with a fingernail or finger. The car never used any oil before  :-\
flyer 0712
Would a glaze buster help to tone the marks down   :-\
Has something caught in the ring? Poss ring damage?  :-[
flyer 0712
Could be...has it ever over heated in a bad way
Quote from: flyer 0712 on 10 March 2017, 18:13:50
Never in my last 20k of ownership
106pete
Looks like something has been trapped between piston on top ring whilst running, unless it's majorly scored (depth), I'd just use some 2k grit wet and dry to smooth it off.
But I'd say take the piston out to inspect and clean before doin any of that, if the foreign body is still there it'll get way worse.
Hope you've caught it before to much damage is done.
Taking the piston out isn't really an option  :-[
Quote from: JamesV6CDX on 10 March 2017, 18:09:23
Probably nothing then. Maybe a bit of carbon fell into the gap between piston and bore when the head came off and wiped the oil off when you span the engine by hand? :-\
It is more or less in line with the gudgeon pin so isn't on a face subject to sideways forces (and hence wear). If I squint I think I can still see the factory honing on the bore surface.
Unless you drop the sump so you can't undo the big end bolts to lift the piston out for a look-see so get the head back on and forget about it........
No - That happened with the engine running.
Maybe it was an artifact released by the death of the turbo?
I still think it was something soft (not a piston ring) and not something to lose too much sleep over
Quote from: Andy H on 10 March 2017, 19:35:15
Sure? That makes me feel a little better as it ran sweet before :y
X30XE
Missing circlip on the end of the pin?  :-\
Omegatitis : [in remission]
Quote from: X30XE on 10 March 2017, 19:57:37
Eg the pin holding the piston to the rod? How would that have happened?  :-\
If we're certain this scoring happened when the car was running, before it was dismantled, that makes me feel a bit better. I was worrying it's something I did during the repair process  :'(
106pete
Quote from: JamesV6CDX on 10 March 2017, 18:50:57
I don't know how big of a deal it is to remove on your car but usually just drop the sump and undo the 2 big end Conrod bolts and out it comes?
