Battlebus performance, thankyou Marks DTM Calib
Started by TheBoy, 11 March 2017, 09:47:39
Quote from: RumpelStiltSkin on 13 March 2017, 10:52:29
so bit reluctant to touch it for a couple of weeks
Chance would be a fine thing...
Quote from: RumpelStiltSkin on 13 March 2017, 19:45:57
Will 'give it some large' on the way to work tomorrow
"That didn't go well"
Shackeng
X30XE
Quote from: RumpelStiltSkin on 14 March 2017, 07:47:19
;D ;D ;D Details....  :D
Omegatitis : [in remission]
Quote from: Marks DTM Calib on 14 March 2017, 15:40:11
I know.....
Of course you know......he probably blames your shoddy workmanship for the problem  :P
Quote from: STEMO on 14 March 2017, 15:53:18
I know.....
Have you spoken to him also?
Fixed at lunchtime, then put all the electricity back in. Just taken it for a spin, and put more go-go juice in it.
Not convinced its starting as well as it should, but fuel was low.  Tomorrow morning will be the test.
So, tomorrow, see if the bugger starts, then if it does, give it a ragging.
Quote from: Doctor Gollum on 14 March 2017, 19:28:33
Snapped the aux belt then ::)
no, I hope not, looks a 'mare to change ;D
Apparently diesel engines need the fuel to go in the engine, not on the engine.
Quote from: RumpelStiltSkin on 14 March 2017, 19:32:42
You ran out then...
It's not too bad IIRC, the tensioner is a bit stronger than a V6 one though! Not sure what access is like on a FWD application.... Always worth checking the crank pulley as it's a harmonic damper type... as you don't want this to happen:-
They start with a few minor cracks... then....! LOL
