Possible O ring in sump. Argh!
Started by JamesV6CDX, 13 March 2017, 15:24:44
Quote from: JamesV6CDX on 13 March 2017, 16:23:40
The head came off due to the previous keeper / mechanic breaking off glow plugs.
Although I secretly wanted to decoke it and check the valve seating
Anyway talking of sex. I just walked into the BMW dealership. The girls behind the counter? DAMN!!! Especially the blonde in the tights.
Next time, I won't turn up unshaved, covered in shit from engine, and in a Mondeo, to buy a £1 seal for my 17 year old 5 series  ;D
It's not what you've got, lad, it's how you use it. Drive your 17 year old beemer through the showroom window, that'll get her attention.   ;D
JasonH
I think you're doing a great job - you're just hitting all the snags that are always there.
My wife laughs when I tell her it's only a simple job and won't take long....although at the weekend I had a job that actually did take the expected amount of time. Ironically it was replacing the glow plugs in my BMW!
Cars, especially old ones are full of hidden "challenges".
X30XE
Quote from: JasonH on 13 March 2017, 17:00:12
I was joking with my next door neighbour friend at the weekend that we should start a youtube channel called "M&M's 5 minute jobs", with the running joke being that they all take at least an hour  ;D
Omegatitis : [in remission]
X30XE
Chin up James. It's not the first time you've a split ring ol' boy; daresay it won't be the last  :D ;)
If it did fall in
and
If any bits of it are small enough to get through the strainer
then they will be little pieces of rubber that will go straight through the oil pump without harming it and stop in the oil filter.
You worry too much...........
Quote from: STEMO on 13 March 2017, 15:46:22
Your problem, James, is that you need to be older than you are.  ;D
Despite now being 33, I still get told this quite a lot  :-\.  ::)
Quote from: JamesV6CDX on 14 March 2017, 21:18:01
33? Kinell...that's gone quick  :o
Bigron
Well, I am 29 and intend to stay that way, as I have done for a few years now..... :P
Ron.
Quote from: STEMO on 14 March 2017, 21:37:00
I was about 24 when I last met you  ::)
Sadly time flies :(
Quote from: JamesV6CDX on 14 March 2017, 22:19:21
Sadly time flies :(
A lot of things happened since then. My life is totally different...........and yours too.
Quote from: STEMO on 14 March 2017, 22:22:48
Sadly time flies :(
You're not wrong :(
Quote from: JamesV6CDX on 14 March 2017, 22:28:48
Sadly time flies :(
You're not wrong :(
Remember when you were stepping out with Tunnie?  ;D
Quote from: STEMO on 14 March 2017, 22:29:42
Sadly time flies :(
You're not wrong :(
gotta look on the bright side. At least, by some miracle, I haven't impregnated anyone  ;D
Quote from: JamesV6CDX on 14 March 2017, 22:32:24
Sadly time flies :(
You're not wrong :(
If you think cars are problematic......... :o
