Possible O ring in sump. Argh!
Started by JamesV6CDX, 13 March 2017, 15:24:44
Terbs
Off topic a bit, but within other context...
Struth, did not realise you were that old, James...me and swmbo thought you were about 25 !!!!
Oh...and by the way.......I found your laptop case in my garage yesterday. Let me know when you are in, and I'll drop it in to you (subject to remembering where you live) ;D
Quote from: STEMO on 14 March 2017, 22:29:42
Remember when you were stepping out with Tunnie?  ;D
Or even going out with loverboy tunnie :P
Now tell me that ain't suspect :P
OMG.....that brings back memories  ;D Do you keep it in case Tunnie steps out of line?  ;D
Quote from: STEMO on 15 March 2017, 18:30:21
I had to go searching through old posts for that one. See, I'm dedicated to serving the OOF community :P
I look little older than a schoolboy in that photo, despite the fact I had changed about three or four cambelts that day.............
I call it exploitation.
To be fair, cambelt party aside, my main memories are being plied with very nice whisky by Hotel21, taking cold beers from TB's ice bucket, and leaning out of the car window to throw up on the way home  ;D ;D
It was only, like, 10 or so years ago  :-X ::)
Quote from: JamesV6CDX on 15 March 2017, 20:50:44
I was in a mucking fuddle that night, but don't recall H21 making it down to Brakkers on that occasion....
Quote from: RumpelStiltSkin on 15 March 2017, 20:59:14
Are you sure?
It may of course well be that, I was so pissed, I am confusing it with another night.
But I could have sworn it was on that occasion, wise old Broocie was bringing out the decent tipples...  :-\
Webby the Bear
Holy shite James.... you look like my work colleagues twin!
RIP Paul Lovejoy
Quote from: JamesV6CDX on 15 March 2017, 21:06:07
Are you sure?
Yup. First time I met Highlander was first Lakes meet...  ...this predated that.
LC0112G
Enough of all this man love - here are some grubby pictures of oily bits when my oil strainer got blocked and ended up destroying the bottom end.
Then I fished out all of the stuff blocking the strainer :
I think the o ring in the second picture is a cam cover bolt hole oil ring, but the dipstick O ring is a similar size. From this I'd guess that even if your O ring does end up in the sump, and gets sucked into the strainer it ain't gonna bung anything up on it's own. So relax, and once you feel better consider a precautionary strainer check.
Seeing that picture reminds me that I found a cam cover o ring in my sump a while ago. It'd probably been there for ages!  ;D
'twas my first cam belt party, I believe.
Memories include following MaxV6 home after extensive surgery to his estate, whereupon he discovered that his scuttle and windscreen wipers hadn't been refitted. ;D
Baked bean tins weren't made out of Tunnie's Senator back then. It was looking a bit crispy, mind. Brush and dustpan at the ready.
TheBoy's neighbour  :-* .. er..  ..is married to a large rugby player.
.. and yes, quite a few cam belts changed. ;D We banished the 4-potters to an "offsite facility" to get theirs done, mind. ;D
Quote from: LC0112G on 16 March 2017, 10:57:04
The sump on a BMW6, is massive and there's lots of stuff to remove before you can get it out. Little things like the subframe.
Unlike the Omega V6 where you undo a dozen(or so) small bolts and the sheet metal cover falls on the floor.
Quote from: Kevin Wood on 16 March 2017, 11:34:47
Ah, yes, the lovely, if a bit shy, Claire :y
Mind you, the first neighbour here, the equally lovely Ros, scrubbed up nicely, and did insist on doing a strip tease very late one night when I had a bit of an open BBQ with some work mates  :-X
Quote from: RumpelStiltSkin on 16 March 2017, 19:34:05
I expect you was too busy drinking Tea to notice.
