Locking wheel nuts
Started by X30XE, 13 March 2017, 22:28:09
X30XE
In the age of smart phones and tablets that you don't eat these things should be illegal.  >:(
Anybody have any suggestions on how to remove 27mm Land Rover size ones without spending a fortune?
The Irwin bolt extractors don't go up to that size it seems and I'm not paying £100 plus for the kit the RAC/AA use.
Note : No access to welding equipment
*P.S - on principal I'm not paying LR a penny for the genuine key.
Omegatitis : [in remission]
ATS removed mine after Kwikfit fitter sheared pins from the original 3 pin style locking wheel nut key
If you don't have the necessary  kit to remove them, drive the car to your favourite mechanic(a technician won't put down his espressmochachinolatte(with extra pink sprinkles and his name caligraphied onto the artisinal paper-mache thermo container in Essex virgin's blood) and pay him to undo the sodding things. Replace them with ordinary nuts/bolts and forget about them forever.
johnnydog
#3
Whilst I don't know what your beef is with Land Rover, are you not 'cutting your nose to spite your face' so to speak?
Is the risk of damaging your alloys, skinned knuckles and blood sweat and probably tears, worth the cost of a replacement locking wheel nut key?
I'd swallow my pride, and get a key from LR, or at least try a LR specialist - THEN bin them.
At least you would also get a set of original wheel nuts to replace the locking wheel nuts out of it.
And it's likely to be a cheaper alternative too.
X30XE
Quote from: Andy B on 13 March 2017, 22:40:18
Any ideas what they used?
X30XE
Quote from: johnnydog on 13 March 2017, 22:44:03
I have no intention of risking damaging my 17 yr old alloys. Equally I have no intention of paying retail price at LR to get a key I shouldn't need to remove 5 wheel bolts to throw them and the key in the bin.  I'd rather spend my money on an appropriately sized set of bolt extractors that would be useful the next time some chump loses the key.
Replacement standard wheelbolts already ordered yesterday btw.  Obviously last resort is give in and take it to my local garage, but that's defeatest.  :P
Quote from: X30XE on 13 March 2017, 23:12:06
Big socket and an even bigger hammer?
Welded a larger nut onto the damaged fastener?
Left handed threaded socket(although I've not seen one that big)?
Various drills and advanced Anglo-Saxon?
The combination of brute force and ignorance that is in plentiful supply at fast-fit tyre operations(and that's just the 'manager' who got the job because he's slightly less likely to beak customer's cars)?
As for the 'bolt extractors' being useful just once, let alone repeatedly, you're living in a fantasy world. PM me your address and I'll send you some to prove that
Varche
When kwik fit sheared my three pins on the omega, i drove car straight to Vx dealer and said please sort it. To their credit they did without damaging the rim. No charge as i said they arent fit for purpose and they were the last people to fit them.
Do people ( in the real world) actually ever have their wheels nicked anymore?
Viral_Jim
When I needed one removing from a car I was buying (vendor lost the adapter so they were paying) a fast fit tyre place used a cold chisel to break part of the stud (to make an irregular shape) and then hammered a socket on to it.
I doubt any solution is going to be technical or subtle. Think brutal but effective  :y
X30XE
Quote from: Varche on 13 March 2017, 23:23:22
Simply put... No. Not since 1998.
serek
Photos of the locking nut??
biggriffin
Top bodge.
If wheel nut is 27mm, go and buy a 26mm impact socket, get very short extension, hammer socket onto nut remove, knackerd extension, replace with good extension, undo with bar.
Hoof'land storeman.
he had a set of various sizes of something like these
http://www.ebay.co.uk/itm/Emergency-Locking-Wheel-Nut-Remover-Removal-Tool-19-26mm-/160650974451?hash=item25678b54f3:m:mUcQ3tkVT25_DD7lv5I8hSg
Quote from: X30XE on 13 March 2017, 23:35:01
In the 13 years I worked recovery, we had one job for stolen wheels. The car was an old Skoda Fabia!
GastronomicKleptomaniac
Pop to local LR dealer or specialist. Ask technician nicely if he has the right key you can borrow for ten minutes. Reward with fourpack of beer.
Worked for me a few years back. .. :y
