Central Heating Issue
Started by Lazydocker, 19 March 2017, 09:49:34
But if a strange one this...
Oil fired boiler in a bungalow (all pipes run up through loft space and drop down to rads).
Boiler fires and runs. Pump seems to run and get hot water to all the rads but it doesn't flow through and return. This has all happened at the same time. No evidence of air in the rads and with bleed screw open there is water flowing.
To top it all off... Pump and 3 way valve relatively new and this all happened suddenly.
Any ideas?
redelitev6
Quote from: Lazydocker on 19 March 2017, 09:49:34
Any ideas?
Sludge in the system restricting flow ?
Quote from: redelitev6 on 19 March 2017, 10:23:46
Any ideas?
But a sudden stop? :-\
It was powerflushed to within an inch of its life 3.5 years ago too
I suspect a bit of air/debris in the pump as I've now got it running properly again (I think!) :-\
Tank getting low? Starting to rot away inside?
My gran had similar in her bungalow, former warm air system, replaced with boiler/rads fitted from above :D
Which tank? Oil is ok... Getting low but still plenty and a plastic tank. Besides, it was heating the water in the system, just not pumping properly. I think it was air/debris in the pump
Quote from: Lazydocker on 19 March 2017, 11:15:41
Meant the oil tank ;) might be picking up a bit of air if it's a syphon connection rather than gravity fed as the level dropos. Plastic tank helps with crud (or lack of) but might still suffer from condensation inside :-\
If it's ok now, you're diagnosis is correct, stress not.
Quote from: Doctor Gollum on 19 March 2017, 11:20:34
Oil and water systems are totally separate, surely?
Quote from: STEMO on 19 March 2017, 11:21:59
Should be, maybe the head gasket's gone?  :-\  ;D                                                and don't call LD Shirly!  :D  ;)  :)
They are, but you're right, if it's heating the water, then it isn't a fuel issue ;)
Quote from: Sir Tigger QC on 19 March 2017, 11:26:01
Haven't you got some teenagers to sort out somewhere? Wales, maybe?  ;D
TD
Any ideas?
My mums bungalow is similar set up except gas boiler and does the same thing since its been fixed. The returns on the rads take absolutely ages to get warm but the rads are hot.
Ive put it down the 'intelligent' pump the plumber fitted Apart from its suppose detect air in it and will keep reversing the flow for 10 mins to try to shift the air up the expansion pipe, its also reduces the flow speed to what it thinks is needed. Some careful balancing of the system was needed to get all the rads hot.
Quote from: TD on 19 March 2017, 11:35:48
Any ideas?
No such cleverness here I'm afraid...
TD
Quote from: Lazydocker on 19 March 2017, 11:43:25
Any ideas?
Ok, but are the rads balanced? if not more water will flow through the ones nearest the pump....
