Any idea how to fix my welder?
Started by Webby the Bear, 19 March 2017, 18:37:52
Webby the Bear
I have the Clarke t135 mig welder. Haven't used it in ages as I have one at work. But it's been at mummy's all that time so today brushed the grime off it and gave it a go. Just pulling the trigger to get the wires to go through it's fine. However as soon as I try to weld and the wire starts to make an arc against the workpiece it seems to birds nest at the motor near the spool. Any ideas  :-\
RIP Paul Lovejoy
Shackeng
Sounds like low electric power at the tip.
Webby the Bear
Cheers mate. Does the copper coloured "tip" help with this. Cos got a feeling I didn't have one on  :-[
RIP Paul Lovejoy
cam.in.head
Has it been stored anywhere even slightly damp? .the wire can oxidise and this maes it have a bad contact on the tip where it gets its power from. I would reccomend removing the tip and fitting a new one and a new reel of wire if even slightly suspect.
Webby the Bear
nah it's not damp or anything and wire looks good. I've got a feeling I forgot to put a tip on it  :-[
RIP Paul Lovejoy
cam.in.head
Yeah its got to have a tip on .otherwise it will spark up inside the shield and either bung up inside there or seize and keep trying to feed .hence the twisted mess at the other end !
Webby the Bear
Quote from: cam.in.head on 19 March 2017, 18:46:27
Got ya. Cheers  :y
Can u mig weld without a nozzle tho?
RIP Paul Lovejoy
cam.in.head
I take it you mean the screw-on shroud ? . You must have that on as it directs the gas around the weld site. Without a shroud or gas the welds will be very poor and spattery ! .
Webby the Bear
Quote from: cam.in.head on 19 March 2017, 18:55:43
Nice one thanks for explaining that  :y
RIP Paul Lovejoy
EMD
Quote from: Webby the Bear on 19 March 2017, 18:43:01
::) ;D
Didn't you get some replacement tips  :-\
Omegatitis
Webby the Bear
Quote from: EMD on 22 March 2017, 13:55:35
::) ;D
I've lost all my consumables. God knows where I've put them. Still they're cheap on the welding site.  :y
RIP Paul Lovejoy
