Clocks wanted
Started by EMD, 26 March 2017, 02:01:54
EMD
Hello , Im after a  V6 speedo/instument panel complete as mine has finally packed up completely now  :(
Omegatitis
omegod
Got one on this 2.5 MFL here if it'll suit?
zirk
Quote from: EMD on 26 March 2017, 02:01:54
You'll need to specify age, engine and tyre size ;)
EMD
Quote from: RumpelStiltSkin on 26 March 2017, 13:35:14
2003  /  2.6  / 235/45/17  :)
Omegatitis
biggriffin
I was lead to believe, there's an ident number on the binicle, that determined weather it would work without needing tech2.
Hoof'land storeman.
Keith ABS
Did have a facelift set but will have to check
Keith ABS
tigers_gonads
I have a PFL set off a 2.5 / 3ltr without MID here if needed  :y
EMD
Is this just  hit and miss to weather a set of replacement clocks will work or not  ??? Whats all this tech2 lark just to swap clocks  :-\
Omegatitis
Quote from: EMD on 26 March 2017, 18:33:13
Saloon or estate?
star_whites
I have a fully working set in my 2001 I'm breaking of your interested.
EMD
Quote from: Doctor Gollum on 27 March 2017, 14:26:48
Saloon or estate?
Saloon
Omegatitis
EMD
Quote from: EMD on 28 March 2017, 17:54:10
Saloon or estate?
Saloon
Im guessing the estate one is not compatible  :-\ :-\
Omegatitis
omegod
I'm baffled why would estate and saloon clocks be different?
Quote from: omegod on 29 March 2017, 18:36:33
Different fuel tanks with different sender calibrations ;)
