Author Topic: Estate aerial mount  (Read 3093 times)
worzelof10acrefield
  • Peterborough
  • Don't snort coke......You might drown
    • Vauxhall Omega 2.6 V6 Est
Estate aerial mount
« on: 02 April 2017, 13:46:49 »
Hi all
I have a broken aerial which i found when washing the car but also found the base rubber falling out.
So thought i would replace both and be done.
On looking for a new one i found 2 types which look identical but 1 is passive and 1 is active.
The active one obviously has a Electrical cable attached too.
Can i tell which mine is without the removal of the head lining or is this a must before.
My system is a Bose setup.
Thanks
Jay
It's 106 Miles to Chicago, We've got a full tank of gas, Half a pack of cigarettes, It's dark and we're wearing sunglasses........HIT IT..
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Estate aerial mount
« Reply #1 on: 02 April 2017, 17:55:17 »
You can access the aerial by removing the trim around the boot opening, and pulling the headlining down a bit.
Buy a new base gasket for the aerial, an ordinary(non GPS) one is about a fiver: LINK
worzelof10acrefield
  • Peterborough
« Reply #2 on: 02 April 2017, 21:30:45 »
Thanks
After a while i did this and found it was a active aerial
I have ordered a shark fin one as this will stop the fouling with the spoiler which i think messed the last one up.
Thanks
Jay
neil74
  • newport
    • 2.6 elite estate.
« Reply #3 on: 03 April 2017, 21:21:37 »
I need one for my car as its very brittle looking and it has split on the side. but I cant see any obvious leaks inside the car yet..
« Reply #4 on: 04 April 2017, 01:07:54 »
Car won't leak as there's another seal where it bolts through... That larger piece is largely cosmetic  ;)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 04 April 2017, 10:36:24 »
Don`t take this as gospel, but I don`t recall ever seeing a non-active OEM beesting aerial on any GM model   :-\
Radio & Decoding Technician
www.dndservices.co.uk
Page created in 0.018 seconds with 16 queries.
