Author Topic: Have I ever mentioned?  (Read 1845 times)
« on: 02 April 2017, 14:26:11 »
Universally, all Netgear stuff is utter shite.  Useless, utter oppsing shite.
Expect a huge outage in next few days as I have to power down everything to reboot 2 of the switches I have here  >:(
Did I mention I oppsing hate Netgear.
I suppose tomorrow, when I call them about this reoccurring issue (across 4 of the tinkers I know of, 2 here, 2 at bro's (which he's educated, and used as hardcore for his building work), I suspect it'll be the usual same crap - reset to factory defaults and upgrade firmware  >:(
Not sure if I mentioned, I oppsing hate Netgear.
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
Re: Have I ever mentioned?
« Reply #1 on: 02 April 2017, 16:03:15 »
So, do you really hate Netgear? :-\ :-\ :-\
 ;D ;D ;D ;D ;D ;D ;)
Lincs Robert
« Reply #2 on: 02 April 2017, 16:08:38 »
Unlike you, I thought you were noted for sitting on the fence and not giving opinions!  ;D
« Reply #3 on: 02 April 2017, 16:16:17 »
So if you hate netgear, why are you using netgear?
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #4 on: 02 April 2017, 16:22:51 »
If they are anything like SMC retards on trying to maintain a chain of hotels wifi system, then their attitude will be, you bought them, your problem, except it wasn't in this case, as the installation company got a big box of door stops back with an accompanying rma. ;D ;D ;D I replaced them with the Zycel equivalent. They weren't perfect but at least they did the job. :y
« Reply #5 on: 02 April 2017, 16:54:15 »
I knew, and had probably mentioned it before, that their consumer shite was shite.  I'd foolishly assumed their business class shite was reliable enough to be used in a business production environment, and was backed up with a lifetime warranty.  And these met a physical size requirement.  So against my better judgement...
Silly, silly me.
« Reply #6 on: 02 April 2017, 16:59:05 »
Cheap Wifi is normally painful.  The Cisco WAP3xx that I fitted at bro's business are looking like they might be heading for the skip if Cisco don't pull their useless fingers out to get some stability out of them.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 02 April 2017, 20:11:11 »
So as were always told, use genuine, and not pattern electriky, bits. :D
Hoof'land storeman.
