Pages: [1] 2 3  All   Go Down
Author Topic: NCDC2013 Advice please  (Read 13289 times)
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« on: 07 April 2017, 21:16:59 »
There is one of these units available, although the CD changer is stuck.
Buying the unit itself would only be for spare parts, but it comes with a colour screen.  This is what interests me.
How easy is it to change my current small, half  b&w screen, to the colour one?
I have a piece of plastic covering the opening were a full screen can go.  Is that going to stop any easy conversion please?
Re: NCDC2013 Advice please
« Reply #1 on: 07 April 2017, 21:51:17 »
Hard. The colour screen must be put into 'delivery mode' to pair with a new 2013, I remember fatty admin had a partial success rate, some ended up bricked.
Might be worth looking to get CD changer refurbished instead, but all these units are so old now no one will touch them. Even if they do,  won't really know what they are doing.
Lot of hassle for very little gain.
Lizzie Zoom
  • South
« Reply #2 on: 07 April 2017, 21:53:52 »
I thought it could be. Thanks Tunnie, that's good enough for me. Another thing I will leave well alone! :y :y
« Reply #3 on: 07 April 2017, 22:19:03 »
Whilst what Tunnie has said is correct, if the 2013 (with busted cdc) is from the same vehicle as the colour screen then they will be fine... simply swap your cdc unit with the dead one and fit 2013 and colour screen.
Ideally this proposed purchase will include the car pass... just in case ::)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #4 on: 07 April 2017, 22:26:09 »
Wot he said. ^ Ive done this recently. The hard part is getting your old unit out without ripping the front panel off.
Lizzie Zoom
  • South
« Reply #5 on: 07 April 2017, 22:38:33 »
Thanks Migv6 :y
Migv6 le Frog Fan
« Reply #6 on: 07 April 2017, 22:58:55 »
Basically - pull your ncdc out and push the new one in its place. Remove instrument panel, remove the current GID display, by removing the four screws which hold it to the instrument panel. Unplug the electrical plug from the GID display.
Attach the CID to the rear of the instrument panel by reinserting the screws. Plug the electrical connector into the CID display. Then locate the other electrical connector, which will be tucked away nearby, with foam taped around it, and plug that into the CID too. Replace the instrument panel. Job done.
This assumes the new NCDC and CID came from the same car. If they didn't, its a whole different ballgame, which cant kick off until its had a tech2 session.
The plastic panel you refer to which covers half the gid screen, is actually part of the gid screen.
« Reply #7 on: 07 April 2017, 23:12:29 »
You're welcome.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 07 April 2017, 23:25:03 »
Dont forget the Bose (Elite) and non Bose thing.
amba
  • Medway towns
    • German V6
« Reply #9 on: 07 April 2017, 23:33:22 »
Anybody still doing Laser replacements on these units ?
Lizzie Zoom
  • South
« Reply #10 on: 08 April 2017, 00:03:11 »
Lizzie Zoom
  • South
« Reply #11 on: 08 April 2017, 00:03:50 »
Thanks Zirk :y
Migv6 le Frog Fan
« Reply #12 on: 08 April 2017, 08:35:35 »
Yep - your car will have Bose and the new unit probably will too, but worth checking as its not always the case.
 One possible issue which I have discovered to my cost, is that if the new system came from a car with a different engine, then the fuel computer settings wont work properly.
Mine came from a diesel, so it needs a chat with Tech2 to reconfigure it to a 3.2.
So - If the system came out of a 3.2 elite its very straightforward, plug & play, apart from pulling your NCDC out of the dash. You really want good quality tools for this, and even then, you might need to file the ends a little to make them more of a defined diamond shape, to get a good grip on the unit.
Less than an hours work to install.
« Reply #13 on: 08 April 2017, 08:58:13 »
The security coding of the Infotainment system in higher specced Elites is done by pairing the devices.
For NCDC2013, these devices are:
NCDC2013
GID/CID
CDC3 (bottom half of NCDC2013, but actually is a separate device)
For NCDC2015, these consist of:
NCDC2015
GID/CID
CDC3 (again, bottom half of NCDC2015)
Telematics
All devices must be paired to each other to work.  All devices must remain together, you cannot just swap out one of the devices.
To replace a device, all devices need to be unpaired, to put them back into delivery mode.  The replacement part also needs to be in delivery mode.
I did an awful lot of work a few years ago to understand the security of these, in order to discover unknown pairing codes (as my NCDR1500/GID/CDC3/Telematics in my MFL MV6 had unknown pairing code, and I wanted to fit a CID), so I probably do know more about these than most.  And yes, I did brick a fair few as well.
« Reply #14 on: 08 April 2017, 09:00:22 »
Oooo, could TB be prepared to sell his CID from the MV6 ::)
Pages: [1] 2 3  All   Go Up
