intermittent wipe/park position
Started by Toledodude1973, 16 April 2017, 16:30:40
cam.in.head
I had a similar issue and seeing as my car (also a 2.6 model) didn't have the variable intermittent wipe I replaced the tall yellow wiper relay with a vw type 99 unit
Toledodude1973
Did yours not park correctly aswell?
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Toledodude1973
Thanks again ,also for relay layout Doc ,looks like i need no.9 as cam says tall yellow one, i will post a wanted
cam.in.head
mine parked ok but mine doesnt have a variable delay just a set amount.the vw 99 relay is a known mod snd is a learning module. you flick up and back to intermittent.then after desired interval you switch intermittent on properly.the relay remembers the time delay and carries  on from there.
Toledodude1973
Thanks Cam essex Al is hopefully sorting part :y
Toledodude1973
Essex Al once again came up with the business and supplied FOC( i might add) the tall relay which i've just fitted ,all works correctly intermittent and park position
So thanks all for help OOF working superbly again :y :)
I would eat my hat, but the dog just beat me to it :D
Toledodude1973
Thanks Doc relay plan was well useful :y
