intermittent wipe/park position
Started by Toledodude1973, 16 April 2017, 16:30:40
Toledodude1973
Hello i should have posted here first before going on wanted section.
The wipers dont park correctly and intermittent wipe doesnt always work. So i want to change relays first before going down motor route, can someone please tell me which relays are required?Its a 2002 2.6 saloon thankyou Paul
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Check the condition of the balljoints, and then the park switch inside the motor before changing the relays.
Toledodude1973
Toledodude1973
Out of interest how do you identify which relay does what in the triangular compartment under the bonnet i see they're numbered but can't see a key anywhere including handbook, thanks for help
Quote from: Toledodude1973 on 16 April 2017, 20:21:45
I linked to the guide ::)
Read it, follow it and report back ;)
Quote from: Doctor Gollum on 16 April 2017, 21:23:18
Did you? I got the mechanical linkage  ::)
Quote from: Andy B on 16 April 2017, 21:40:06
Reply #1 ::)
Quote from: Doctor Gollum on 16 April 2017, 21:49:34
Reply #1 ::)
Yep ..... as before.  A mech guide to the linkage ..... no site nor sound of relays etc
Quote from: Andy B on 16 April 2017, 22:01:00
Reply #1 ::)
You did compare the title of the post and the title of the guide... ???
The relays are, at this point, largely irrelevant.
Pending a reply regarding following the guide, then if it's ok with you, I will possibly post a link to the relays... not that it's a secret, but people should be allowed to look for what they seek.
Toledodude1973
You're all a great help i will report back tomorrow thanks Paul
Quote from: Doctor Gollum on 16 April 2017, 22:05:43
Reply #1 ::)
I'd  agree with you other than the fact intermittent doesn't work ..... sounds electrical to me
Ignoring that they don't park correctly ::)
My money is not on the relays...
Quote from: Doctor Gollum on 16 April 2017, 23:39:05
If it was just that they'd slipped on the motor's taper, the intermittent would still work ...... but park in the wrong place. I never said the relays were fubar'd ....... just that your link didn't  answer the question
Toledodude1973
Just changed whole motor and linkage for known good one but no better ,intermittent not working still and doesnt park correctly.
Going to have to try relays i guess but i dont know where they are or which ones? its a 2.6 saloon
Would appreciate more help thankyou Paul
