Problem cant find where the 3pin plug need to be attached
Started by Alexi777-77, 20 April 2017, 14:43:23
Alexi777-77
Hi omega owners need help please.
Changed the gasket seals on my omega elite 3.0  and can't find where this plug goes no spark at all.
It's on the back of the engine 3 pin one will try to send picture please help.
My number 07447045029
Alexi777-77
Trying all week to find where that plug goes but no luck
Crank sensor is my starter for ten ;) it lives down by the oil filter...
zirk
Quote from: Doctor Gollum on 20 April 2017, 15:20:21
What he said, plug is right at the back of the block right hand side.  :y
Alexi777-77
No luck.
Can we do video chat so I can show what plug I mean
Quote from: Alexi777-77 on 20 April 2017, 15:44:28
No luck.
Or just post a picture, the eggheads on here will know what it is.
Alexi777-77
It's something else crank shaft sensor it's in place no idea what it could be
zirk
Another one then, plugs into to module approx middle right hand side of the alloy Pentium.
Is it a male or female plug?
What direction does the wire run off in?
Did you disconnect a plug like this when doing the seals?
Does it have rounded or square edges?
Chances are that a new crank sensor has been fitted and the old one left in place (the originals are clipped to the oil cooler pipes and can be tricky to fully remove) you may have connected the wrong one up (e.g. the old one) and hence the issue
Alexi777-77
Please can I phone you with video chat it will be much easier as I'm useless and completely lost.
My mobile is 07447045029 please please please
Alexi777-77
I'll put everything together and see possible it was the problem.
Thanks
Alexi777-77
Thank you very much everybody for your help got started and all good😁
