Help finding oil filter zafira tourer
Started by brian36, 22 April 2017, 21:15:35
brian36
Hi all had to call rac out today for my mobility car and while,checking one thing he found that my oil filter was leaking a bit but he has tried every where to find another but today we have tried dealers etc for miles around but seems a back order on them. We are leaving in morning at 7am to go from Milton Keynes to Lake District then Edinburgh on Monday does,anyone have a spare or know where I can get one en route please not sure of part number but it's 15 reg 2. Cities but apparently different engine thing dth whatever that is but hope someone can advise many thanks
Between osf driveshaft and osf wishbone back of engine...
You won't see it without removing the undertray...
Quote from: Doctor Gollum on 22 April 2017, 21:45:06
I think he wants to buy a new one.
Quote from: Andy H on 22 April 2017, 22:12:13
Good point well spotted... Third drink of the evening just kicking in ;D
omegod
Milton Keynes branch of eurocarparts is open 7 days a week, failing that search through the branches on this link to find one thats on your route  :y
http://www.eurocarparts.com/store-locator
Motorbiking sure requires main dealer input :-\
omegod
Quote from: Doctor Gollum on 22 April 2017, 22:31:57
Must be the 5th drink by now ?
Quote from: omegod on 22 April 2017, 22:39:19
Absolutely... but that one is all down to predictive text ;D
Motorserv up in Wolverton normally have a good range of service parts in stock.
Obviously an oil filter is engine specific, but don't believe you have stated what engine.
brian36
Ok thanks tonallnonnway now just checked still leak but still small at moment so will try get one asap thanks for help
It can only be dripping on to the undertray, so keep an eye on the level and top up as necessary. Don't let it spoil your trip.
No idea which engine but, the usual is a leak from the oil seals on the oil filter cap as they can rarely can be bothered to change them fro the new ones that come with the filter.
Very easy to change out and a filter should be available from pretty much anywhere
brian36
Thanks all I managed to get a new filter in Edinburgh seems very large back order on them so assume a problem
It did however cause finding another problem when fitting I also have a leak from sump and the technician says somewhere up middle too. But he says needs to go get checked properly at my dealer and he said it should get us back ok.
Anyway update today contacted Vauxhall dealer told get call back on Friday afternoon no call back called again Saturday morning again no call back so guess now just wait but thanks to all for help and to mark it's good to hear from you it's been a while hope all ok with you
Right...so zafira tourer on mobility. Less than three years old and you had to call the RAC out. After fixing the original problem he found an oil leak. When fixing that oil leak, two more became apparent.
If all of that is correct, it's not a very good advert for the car, is it?
Lizzie Zoom
#14
Quote from: STEMO on 30 April 2017, 09:42:14
No it is not.  Indeed, as it is a Mobility car that is fully covered for all repairs and servicing I would just put it in to the Vx dealer and get them to sort all the problems out.  That is the benefit of having a Mobility car ;)
PS Be careful in what you touch on the engine of the car as you cause problems with your Mobility agreement and the warranty that covers the car.  It is not your car, so get the dealer to do what they should be doing anyway. :)
