Potential Omega replacement ... :(
Started by Entwood, 23 April 2017, 20:45:15
Thought I'd found a "possible" contender ...
http://www.elitecar.co.uk/used-cars/holden-commodore-bordon-201701191461751
but no tow bar and, apparently, no chance of getting one in the UK ..  :(
Not inexpensive for a nine year old car. :)
Quote from: tunnie on 23 April 2017, 20:55:40
Not keen on those looks one bit, but that kind of budget, I'd look to something like this:
http://www.autotrader.co.uk/classified/advert/201701271713275?make=JAGUAR&advertising-location=at_cars&fuel-type=Petrol&postcode=tw89de&sort=sponsored&radius=1500&onesearchad=Used&onesearchad=Nearly%20New&onesearchad=New&model=XF&page=3
But diesel is better for towing, so I'd look at this:
http://www.autotrader.co.uk/classified/advert/201704214654763?fuel-type=Diesel&make=JAGUAR&sort=sponsored&model=XF&radius=1500&advertising-location=at_cars&postcode=tw89de&onesearchad=Used&onesearchad=Nearly%20New&onesearchad=New&page=1
Only if a) the towing vehicle weighs 6 Tonnes and the trailer weighs 38 Tonnes ...... or b) the towing vehicle floats on water or c) the towing vehicle runs on rails
Please note the proposed vehicle had a factory fit LPG conversion ... please compare apples with apples, not pears ...   :)
You'd turn your nose up at a Range Rover V8 diesel? Sure that's about best tow car going   :)
You are towing a burger van, diesel makes perfect sense? I think a run in fatty admin's XJ would make you re-consider.
While I've enjoyed LPG for many years, I don't think i'd ever run another. Diesels are very refined and deliver excellent torque, without huge RPM and I'm comparing like for like. 2.2 petrol vs 2.0 diesel.
Given large capacity petrol's are fairly rare these days (hence your replacement issues) - only with new tax rules could they come back.
Also first link, was to a petrol XF. :)
Quote from: tunnie on 23 April 2017, 22:00:09
I have to agree ref diesels. The power and torque from my '10 Mondeo 6 speed is really, really impressive. Especially given it will do 50mpg all day long
Quote from: Entwood on 23 April 2017, 21:42:07
Probably not factory fit and if it is then servicing it may be an issue ;)
Lets get one thing absolutely clear ... unless I come out of retirement and retrain as either a truck driver, train driver or boat driver .. I will NOT, out of any choice, drive a smelly, polluting, child damaging diseasel..... period.
And yes .. I would "turn my nose up" at a diesel (or petrol) Range Rover .. if given one I would sell it. I don't want/need a 4X4 chelsea tractor, I don't want/need a soot chucker.... I have towed with Pajeros, Showguns, Rangies, Landies, Discos ... yes they all work .. but I don't want or need one.
If/When the omega goes I would "like" a rear wheel drive, saloon, NA V6 petrol of around the same power, with, hopefully, sufficient boot space to take an LPG tank. At the moment that appears to limit me to BMWs, Mercs, & Jags, but the odd other option appears .. :)
I have to say that my diseasal tows my caravan effortlessly.  My Omega was a good tow car,  but my Merc is much better. ... 374 ftlbs of torque makes a huge difference.
That car is probably factory fit as it was a factory option... Without looking, it's an '09 Commodore Executive registered locally to me... I used to see it regularly enough.
Tow bars readily available for it, 2,300 Kgs being the factory design iirc... Insurers might require some hoop jumping, but it can and will tow ;)
As for diesel V8 Range Rovers... Really? You have read Jws guide?
Migv6 le Frog Fan
#10
Is a Lexus LS430 / 460 an option Nige ? V8 rather than V6, but I'm sure you could learn to live with a couple of extra cylinders.
Well equipped, I believe they have self levelling, and built like tanks.
http://www.ebay.co.uk/itm/2007-57-Lexus-LS460-4-6-V8-Auto-Service-History-A-FULL-Spec-/252691095969?hash=item3ad59021a1:g:QYUAAOSwEzxYXO86
Quote from: Doctor Gollum on 23 April 2017, 23:38:24
They may be available but the current UK laws require it to be type approved, which it won't be because it's not a mainstream European car... Couldn't get one for the Brother in Law's Jag either ::)
Quote from: Andy B on 23 April 2017, 22:56:48
Yeah can imagine with nearly 400  :o - Torque is king when it comes to towing, BHP matters little really. With just my 4 pot the update in torque is good, as it has around 320Nm (236 lb.-ft.)
My 2.0 TDi has more torque than my 3.2 Omega, as it only has 290Nm.
Lincs Robert
Quote from: tunnie on 24 April 2017, 09:07:22
Mk1 Focus 1.8 Tdci (115 bhp) has more torque than an Omega 3.0!  :o
Oh, and even over there the LPG wasn't generally fitted at the factory but rather by an aftermarket supplier before delivery 😉
